625
  1. Gopalakrishnan L
    Cupcake Jan 25, 2019
    Gopalakrishnan L , Jan 25, 2019 :
    Updated my OnePlus 5T and I feel the device is getting slow and draining battery fast. Anyone has any suggestion to me or have the same problem??
  2. vincent.manjuran
    Gingerbread Jan 25, 2019
    vincent.manjuran , Jan 25, 2019 :
    I think this should help you
  3. Gopalakrishnan L
  4. vincent.manjuran
    it's only on pie. and you need to update it on Play Store first.
  5. Rutvik Naik
    Rutvik Naik , Jan 25, 2019 :
    the pi update has some problems such as if I've kept the shutter sound of camera off even then it makes the shutter sound, that's annoying, another problem is with the recent apps switching, if I've opened WhatsApp and then switch to home screen and then go to recent app then it switches to the app i was using before WhatsApp whereas it should have opened WhatsApp which was happening in previous version of oreo.... plsss fix it asap
  6. ChinaMarius
    Donut Jan 25, 2019
  7. Louioo
    Honeycomb Jan 25, 2019
    Louioo , Jan 25, 2019 :
    Just received this updated OTA (UK, London) - Anyone else still having issues with 9.0.3 or should I install?
  8. G_Dushyant_Pratap_Singh_
    Eclair Jan 25, 2019
    G_Dushyant_Pratap_Singh_ , Jan 25, 2019 :
    i have Installed this morning everything looks good so far better than 9.0.2, battery also going good (India)
    elend777 and Louioo like this.
  9. SevenOptimus
    Froyo Jan 25, 2019
    SevenOptimus , Jan 25, 2019 :
    Regarding the shutter sound, the consensus seems to be that it's happening because in some countries it's now illegal to disable it. As for the recent apps thing - it might be a bug; report it at https://forums.oneplus.com/feedback/
  10. M1548410046405
  11. danishdaycare
    Ice Cream Sandwich Jan 25, 2019
    danishdaycare , Jan 25, 2019 :
    You don't read prev posts properly or know how to Google.
  12. JAMES903
    Froyo Jan 25, 2019
  13. Ansarika46
    Ansarika46 , Jan 25, 2019 :
    After update of one Plus 5, my incoming call ring tone got silent.
    Then factory settings was fix this issue
    doekus likes this.
  14. eye842
    Lollipop Jan 25, 2019
    eye842 , Jan 25, 2019 :
    Apart from notifications got all messed up and strange behaviour of apps with lock screen permissions it looks smooth here (Denmark).
  15. bonden_91
    bonden_91 , Jan 25, 2019 :
    Im using Cmore app. Its an streaming app for sports and movies.. after the update its lagging when im watching a hockey game.. please fix this
  16. Vitor Valeri
    Eclair Jan 25, 2019
    Vitor Valeri , Jan 25, 2019 :
    I know that's how you set the slider. It turns out that the option to add phone calls as an exception to mute has disappeared! It is simply that and there is no way to change anything.
  17. S1510166958084
    Donut Jan 25, 2019
    S1510166958084 , Jan 25, 2019 :
    anyone facing issue with speed dial ( most dialled contacts) it gets reset every day morning or afternoon. problem from 9.0.1 still in 9.0.3 its there.
  18. firedeamonxen
    Eclair Jan 25, 2019
    firedeamonxen , Jan 25, 2019 :
    then you can raise enhancement request. there's all we can do right now.
  19. bizius63
    Donut Jan 25, 2019
    bizius63 , Jan 25, 2019 :
    the same for me...in addition after clearing the cache and the data of the Google Play and the Google Service, i haven't received app update notification.
    It is normal?
    Thanks in advance for the help
  20. LSega
    LSega , Jan 25, 2019 :
    Decreased battery life by half, decreased screen brightness. I want to go back to the previous version of oxygen, how can I do it?
