625
  1. Thesebf
    Eclair Jan 26, 2019
    Thesebf , Jan 26, 2019 :
    xkanedax likes this.
  2. Tcat007
    Honeycomb Jan 26, 2019
    Tcat007 , Jan 26, 2019 :
    On my OnePlus support page in USA.
  3. F1548531063730
    Cupcake Jan 26, 2019
    G1518103186467 likes this.
  4. N1548440556128
    Donut Jan 26, 2019
  5. DogeAlpha
    DogeAlpha , Jan 26, 2019 :
    I have a problem with data connection.
    4G doesn't work when my sim is in slot 1 (it shows only H+) but it works on slot 2.
    Is it the carrier's fault, oxygenos, sim card or is it a hardware problem?
    Didn't have this issue in oxegenos 9.0.2
  6. xkanedax
    Donut Jan 26, 2019
    Thesebf likes this.
  7. N1548440556128
    Donut Jan 26, 2019
  8. Q1545504703112
    Q1545504703112 , Jan 26, 2019 :
    Download the zip file for 5.1.7, you should be able to find it on XDA. Copy the zip file onto the root folder of your phone. Then go onto local upgrade on your settings. Choose the zip file that you downloaded and press ok. When the phone has flashed the file and reboots, go into recovery mode and click on wipe cache and data and then click on erase everything (factory reset). The phone will then be running Oreo again
  9. D1548533893155
  10. D1548533893155
  11. jaisega
    jaisega , Jan 26, 2019 :
    My phone says 9.0.3 but the build number says January 19... is this correct? the WiFi still hangs and i have to turn it off and on again.... is this fixed in the new update
  12. Kamal Hans
    Ice Cream Sandwich Jan 26, 2019
    Kamal Hans , Jan 26, 2019 :
    Best way out is to contact a Oneplus service centre & descibe the issue. They may ask you to bring your phone over; alternatively, you could request them to do the job via remote access.
  13. Kamal Hans
  14. Kamal Hans
    Same thing happened with me.
    Take it to a Oneplus service centre, they'll flash the update & get your phone working properly again.
  15. P1548535520070
  16. G1518587326611
  17. Bibin Alexander
    Froyo Jan 26, 2019
    Bibin Alexander , Jan 26, 2019 :
    Thanks for the quick 5 cents. I also realized that now the battery drain has drastically reduced though it was majorly due to brightness and Google service. Rest all looks the same as of 9.0.0. I hope this is stable version now. Haven't found any hiccups with the fingerprint sensor though.
    All an all its a very stable update I must say as of my 9 hours of usage.
  18. Tcat007
    Have you trained it for a week?
  19. micharu
    Gingerbread Jan 26, 2019
    micharu , Jan 26, 2019 :
    i got finally the pie update i want to ask that the lower display light on pie is intended and i have some lags and memory problems on my OnePlus 5t 8gb/128gb so is there another hot fix planned (9.0.4) for it
    p.s.: noticed that fingerprint sensor is much slower or unresponsive after pie update
  20. Kshitij Rajpurohit
    Kshitij Rajpurohit , Jan 26, 2019 :
    I have issues after this update my microphone is not working after this update in any application I have to restart my phone again and again to make it work like when I re start the phone it will work as soon as I go back from any AAP wen I came back it Stop working
