625
  1. G1548649285809
    Cupcake Jan 28, 2019
  2. Zaphodrocks
    Ice Cream Sandwich Jan 28, 2019
    Zaphodrocks , Jan 28, 2019 :
    Uhh who should solve the issue?
  3. I1530254299940
    Eclair Jan 28, 2019
    I1530254299940 , Jan 28, 2019 :
    9.0.3 is the most stable pie update for me. I'm getting 9.45hrs sot constantly (6 recharge cycle) and no lagging. I don't know why many users are getting issues. this is what I have done.
    factory reset and installed 9.0.2.
    then updated to 9.0.3 through OTA.
    danycmoi likes this.
  4. 6969123
    6969123 , Jan 28, 2019 :
    ambient display is f'd up!
    I lost my volume control to once it wouldn't change on changing the volume level.
  5. Archanaavr
    Archanaavr , Jan 28, 2019 :
    my phone freezes after sometime of inactivity after the latest update ...I tried to disable battery optimisation option but still after sometime the fingerprint sensor or unlock button don't work and no calls or alerts buzz and phone is frozen and the only way out is to reboot the phone....can I downgrade the update somehow?or what is the workaround for it?
  6. mankind
    Eclair Jan 28, 2019
    mankind , Jan 28, 2019 :
    If i remember correctly, back in stock oreo rom, if i remove the clock in status bar, the clock still showing if i pull down the notification bar, but now in stock pie rom, the clock disappear completely both in status bar and notification bar pull down if i remove the clock from status bar settings. Anyone know how to bring the clock back in notification bar pull down without having the clock in status bar?
  7. Q1522342242876
  8. Zaphodrocks
  9. BeastCheng
    BeastCheng , Jan 28, 2019 :
    i am still not getting email notifications from the Gmail app. Problem started since 9.0
  10. Q1522342242876
    Q1522342242876 , Jan 28, 2019 :
    thn y this is empty??
  11. Yatin_Asri
    Gingerbread Jan 28, 2019
    Yatin_Asri , Jan 28, 2019 :
    well at first thanks mate for sharing your findings. yes I noticed that under facelick the option that's says unlock when screen is on is YES but it's greyed out for me to make any changes. I haven't add any facelick though.Any idea on how should I go about disabling this option? cheers
  12. go2shibu
    go2shibu , Jan 28, 2019 :
    Is there any chance to revert back the speed dial and multi process layouts? After done the update it looks worst.
  13. Majmn1
    Majmn1 , Jan 28, 2019 :
    why does the help window from google pop up every three minutes? its so irritating. can you fix this? cant watch a movie without being reminded that there is help available even when u dont need it.
  14. Joseph Moses Jeyaraj
  15. U1519406939778
    U1519406939778 , Jan 28, 2019 :
    After upgrading to 9.0.3, I'm not able to make noise free calls, some irritating noise is coming for both incoming and outgoing calls.
  16. firedeamonxen
    Eclair Jan 28, 2019
    firedeamonxen , Jan 28, 2019 :
    Hi,
    So it has been 2 days since I have upgraded onto OOS 9.0.3 and I can safely say it's as equivalently stable as OOS 5.1.7 for the Oneplus 5T.
    Without further a due let me state some of the key things that I did before and after updating my device.
    NOTE: I did a dirty update and my device was on OOS 5.1.7.
    Steps:
    1. I wiped the cache of my Apps from the storage (on OOS 5.1.7).
    2. Then wiped clean the cache from recovery.
    3. Updated my device via the OTA I got by default, did not use any kind of third party update tool etc.
    4. After update again wiped clean cache from recovery.
    Key Notes after UPDATE:
    * After the update I did not notice any kind of lags or stutters that people are reporting.
    * Haven't noticed any kind of issue with Google Play Services or updating or installing apps from the Playstore.
    * Did not notice any kind of sever hit to by battery timing, however I would suggest re-calibrating your battery soon after you rebooted device onto 9.0.3.
    * However do note that camera shutter sound muting is geo tagged and I cannot comment on it right now.
    So guys give it a go. It's good it's stable.
    Happy Upgrading to you.
    Faragondk, danycmoi and ravi603 like this.
  17. Punit G
  18. Kamal Hans
    Kamal Hans , Jan 28, 2019 :
    It's facelock, not facelick.
  19. Kamal Hans
    After the new update, why do i hear the camera shutter sound even after turning it off in settings? is that a bug?​
    Yes it's a bug.
    Unfortunately many people in the OP community have been tossing around as a fact that Indian laws forbid muting the shutter sound, whereas there is no such law here.
    That may have influenced Oneplus to prevent its muting, even tho the button is there.
    Earlier on also, OP recognised it as a bug & fixed it in OOS 4.5.7.
    Therefore, if we India keep reporting it as a bug, OP will fix it.
  20. Joseph Moses Jeyaraj
    Joseph Moses Jeyaraj , Jan 28, 2019 :
    Oh yes .. thank you for clarifying... i really hope they fix it soon.
