625
  1. blasbenoit
    Cupcake Jan 31, 2019
    blasbenoit , Jan 31, 2019 :
    Hey man,
    I have the exactly same issue and i thought it was my carrier but then i discover that my Honor 7x wasnt doing this...im still waiting for a fix.
  2. EvilSibling
    EvilSibling , Jan 31, 2019 :
    I'm so glad it's not just me.
    also, I think I've found the issue often occurs when the phone was joined to a wifi network but moves out of range. like as I type this I've stepped out of my office on where I no longer have wifi coverage and my cellular is busted again.
  3. Soulsurfer919
    Honeycomb Jan 31, 2019
  4. simar139
    Eclair Jan 31, 2019
    simar139 , Jan 31, 2019 :
    One of the most bizzare looking bug/problem. I can't send sms from my phone. Tried both the sims. And the sims are working perfectly in other phones.
  5. OnePlus_Heard_U
    Gingerbread Jan 31, 2019
    OnePlus_Heard_U , Jan 31, 2019 :
    Hey
    clear the storage data from App info of msg app and that should work.
    see screenshot
    Let me know if that helped u.
  6. OnePlus_Heard_U
    Hey did you try basic steps
    I am sure you restarted the phone.
    Reset Network settings.
    What is the Network carrier you are using. Try diff Network carrier and conclude is that with all Networks or specific.
    Good that you checked on different phone. Report the bug anyways... Good Luck...!
  7. ivannhf
    Donut Jan 31, 2019
  8. sandy.cbitkings
    Eclair Jan 31, 2019
    sandy.cbitkings , Jan 31, 2019 :
    You should have masked your friends number before sharing the pic here. Your friend number went public now.
  9. simar139
    Eclair Jan 31, 2019
    But will it not delete all my msgs n chat history?
  10. EvilSibling
    how do I report the bug? I thought posting to the forum was the only way to submit bug reports.
  11. simar139
    Eclair Jan 31, 2019
    I tried to clear the storage as well. Still the same error
  12. D_24
    D_24 , Jan 31, 2019 :
    simar139
    Dial *#*#4636#*#*>Phone information>SMSC>'ENTER NUMBER'>update>refresh
    'Enter number' is sim centre number for eg. for Airtel it is '+919898051914'
    It's different for every operator, dial same code on other Android, then try 'refresh' in SMSC section
  13. munsif.raza
    munsif.raza , Jan 31, 2019 :
    can any one help me , after OS update, my contact searching has become very slow. even during call, I can not search any number
    plz support me
  14. Allan_Limpoco
    Donut Jan 31, 2019
    Allan_Limpoco , Jan 31, 2019 :
    try rebooting your phone a few times, let's hope it does the trick..
  15. vsbvivek932
    Donut Jan 31, 2019
    vsbvivek932 , Jan 31, 2019 :
    oh my goodness, stills there are so many bugs and issues are there, messaging app, phone app, WhatsApp crashing, some apps are not responding after minutes of use, jelly effect... please one plus do something
    crishurazvi likes this.
  16. Arnaud_Ieè
    Eclair Jan 31, 2019
    Arnaud_Ieè , Jan 31, 2019 :
    The most annoying for me after update is the phone isn't smooth anymore in scrolling or opening/closing a app folder on main screen.
  17. Ismet kjerimi
    Froyo Jan 31, 2019
    Ismet kjerimi , Jan 31, 2019 :
    New Bugg __ No vibration in incoming calls ,.... No vibration after connected .Oneplus team are u kidding me , please fix this beginner buggs
  18. Soulsurfer919
    Zaphodrocks likes this.
  19. boem2001200q
  20. G_Tal_Haloutz_JKVK
    G_Tal_Haloutz_JKVK , Jan 31, 2019 :
    Parallel apps stoped working after update.
    Both apps normal and parallel shows the same user (sim) and there is now way to use the second sim account.
    Major functionality that stopped.
    HELP
