625
  1. Yatin_Asri
    Gingerbread Feb 3, 2019
  2. Tcat007
    Honeycomb Feb 3, 2019
    Tcat007 , Feb 3, 2019 :
    I'm sure they have issues. Lots of suggestions here how to solve them. I think OnePlus screwed something up on the ota for 9.0.0 which created some issues if installed "automatically". Some people may have tried to fix them without knowledge enough to do so, and messed their phone up further. Some people may have bogus apps messing with the phone. Some phones may be bad. Some people in India just want their camera silent. The complaints here are probably a small fraction of total people with no issues, same with any phone. OnePlus has stepped in and showed how to roll back, and I'm sure are working on a more stable build. Hopefully they'll post a detailed description on how to move forward.
    I'm just saying the current build is stable, as is ob24. How and if you want to get there is up to you. Or just stay on Oreo and don't update again if you're happy with your phone.
    W1523980290575 and cubanorafter like this.
  3. PoorvaGupta
    Cupcake Feb 3, 2019
    PoorvaGupta , Feb 3, 2019 :
    no one is here to misguide anyone. those having problems are reporting it. it is good if you do not have any problem in your phone. hope it stays that way for you.
  4. D1532927030530
    Cupcake Feb 3, 2019
    D1532927030530 , Feb 3, 2019 :
    my mobile is showing dark screen and when I press the power button and when I press the button again it's showing the same dark screen and this was happening since the android pie update
    W1510775490328 likes this.
  5. Zaphodrocks
    Ice Cream Sandwich Feb 3, 2019
    Zaphodrocks , Feb 3, 2019 :
    The Pie update is perfect except for two things.
    1. Horizontal scrolling in Recent
    2. The clock on the left
    MvD66 likes this.
  6. U1520013512142
    Cupcake Feb 3, 2019
    U1520013512142 , Feb 3, 2019 :
    camera shutter sound won't stop although i have switched it off from setting. frequently my phone boots automatically.
  7. Tcat007
    I like the full page scroll, easier to check a page without actually going back to it. Yeah OnePlus should give a clock option for unrooted users. Easy to move clock if rooted.
  8. Kamal Hans
    Kamal Hans , Feb 3, 2019 :
    Its a bug that Oneplus will have to fix, like they did earlier in OOS 4.5.7.
    Presently they appear to be busy( hopefull ) trying to come out with a truly stable build of Pie.
  9. Kamal Hans
    Got it, thanks.
  10. Kamal Hans
    Re the camera shutter sound issue, its a bug for owners in India that Oneplus will have to fix as they did earlier in OOS 4.5.7
  11. Tcat007
  12. W1510775490328
    Cupcake Feb 3, 2019
    W1510775490328 , Feb 3, 2019 :
    1. Too many times mobile is hanging,
    2. Unlock phone also hangs.
    3. Phone hangs while receiving the calls as well.
    please release a hot fix at the earliest.
    arpit1+ and U1520013512142 like this.
  13. bonden_91
    bonden_91 , Feb 3, 2019 :
    Am I the only one having problems with the gps apps (waze,google maps)? It doesnt locate where I am... I need to restart the apps a few times even then it might not work.. and live streaming is lagging.. anyone else?
  14. Kamal Hans
    There we go again.
    The Beebom piece is wrong on two counts.
    Samsung: I have personally checked the muting ability 2 days back on a Samsing ON Nxt phone.
    The writer also says that one can do it easily on a Oneplus phone which is obviously incorrect.
    He wonders what made Google bring back this ability last year; its because owners complained!
    Just like OP owners here did earlier leading to Oneplus fixing the shutter sound issue for India in 4.5.7 ; we were able to mute it right upto 5.1.7.
    Google has fixed it in 2018 for India; Pixel phones here are able to mute the shutter sound, so is Nokia 6.1 plus & Jiophone, which again, I have confirmed personally.
    There is clearly no law in India that prohibits muting else Google, Nokia,Samsung, Jio couldn't have allowed muting.
    If Oneplus has neglected to enable muting the shutter sound again in Pie, it doesn't follow that its because there's a law against it; its because once again,Oneplus has made a mistake which they'll have to correct.
    We users in India can't just accept it with bowed heads; we have to keep reporting it as a bug & rebut any post that tries to explain it away on the basis of gossip/rumours/baseless assumptions.
  15. JamshedKhan
    Cupcake Feb 3, 2019
    JamshedKhan , Feb 3, 2019 :
    Device and app everything is getting hanged after 9.0.3 update. Always need to restart the device.
  16. Timmy75paris
    Cupcake Feb 3, 2019
  17. eye842
    Lollipop Feb 3, 2019
    eye842 , Feb 3, 2019 :
    Doesn't have to be a mistake, you need to look at that possibillity. OnePlus knew about the shutter sound problem for Indian OP5/OP5t since beta Pie, all feedback reports, incl. beta feedback are flagged solved this time around, back in 4.5.7. they wasn't.
  18. Hve22
    Cupcake Feb 3, 2019
    Hve22 , Feb 3, 2019 :
    After update tot 9.0.3 the fingerprint sensor cannot wake the phone after standby.
    is there a workaround ?????
  19. Razvan B.
    Razvan B. , Feb 3, 2019 :
    somebody here in this post said that it you turn off the adaptive battery setting it will work.
    i do not know because i didn't update to Pie so i do not have problems with gps
  20. PokiX
    Jelly Bean Feb 3, 2019
    PokiX , Feb 3, 2019 :
    Il guess/hope Google themselves add a way to customize status bar including moving clock to the right. Not sure OP would do it, we want near stock after all !
