625
  1. ch_suryaprakash
    Donut Feb 9, 2019
    ch_suryaprakash , Feb 9, 2019 :
    switch off the phone
    press volume down button and power button for 5sec
    a screen appears
    select wipe data
    -> clear cache
  2. Zaphodrocks
    Ice Cream Sandwich Feb 9, 2019
    Zaphodrocks , Feb 9, 2019 :
    Even my apps and UI stuttered for a couple of days after the update even after wiping the cache .Then I left the phone on the charger overnight. That optimized the apps and the phone has been fast and smooth ever since. Check if that works for you too.
  3. jmarks
    Honeycomb Feb 9, 2019
    jmarks , Feb 9, 2019 :
    I agree with you @Zaphodrocks.
    I'm not a fanboy of anything. If something works well I'm satisfied, otherwise I point out the bugs and I look for better.
    My OP5 work fine with OOS 9.0.3, this is the reality!
  4. ArpanMistry
    Cupcake Feb 9, 2019
    ArpanMistry , Feb 9, 2019 :
    After updating my op5t with 9.0.3, the adaptive brightness feature is totally crashed..., my device is like unable to sense anything, I have to manually change the brightness level of my device, help me solve this problem.
    chetan_tib and O1548390821613 like this.
  5. Tcat007
  6. Compux72
    Gingerbread Feb 9, 2019
  7. Cervantes
    Lollipop Moderator Feb 9, 2019
    Cervantes , Feb 9, 2019 :
    Hi
    The update thread is a thread of questions and/or commentary
    Please, read the first and third post
    Thread merged
  8. chewsifer
    Froyo Feb 9, 2019
    chewsifer , Feb 9, 2019 :
    Contact OP directly. This is just a forum which they don't monitor.
  9. Hardikkhurana1990
    Cupcake Feb 9, 2019
    Hardikkhurana1990 , Feb 9, 2019 :
    Same here.....i need to go to the settings for the same
  10. manishkak
    Cupcake Feb 10, 2019
  11. EvilSibling
  12. Zaphodrocks
    Ice Cream Sandwich Feb 10, 2019
  13. Hebbnag
    Gingerbread Feb 10, 2019
    Hebbnag , Feb 10, 2019 :
    long press power button go to recovery option and erase cache tats it.
  14. djentleman
    djentleman , Feb 10, 2019 :
    BUG ENCOUNTERED.
    Multi-touch SIMULTANEOUSLY doesn't work for 3 or more fingers.
    Clean installed on OP5 and tested.
    You can try by yourselves using touchscreen counter app, try doing a simultaneous multi touch using 3 or more fingers at the same time.
  15. Shruti_Bhutra
  16. ArpanMistry
  17. chetan_tib
    chetan_tib , Feb 10, 2019 :
    After update to OS 9.0.3, my phone is getting hanged a lot and battery is draining very fast. Also WhatsApp is getting crashed very frequently and seems this os is not supporting it. what to do here please assist.
  18. Deepakjames13
    Deepakjames13 , Feb 10, 2019 :
    please provide new updates as the battery is draining very fast for one plus 5 and the call recording or call mutes starts automatically when placed near ear. phone is getting hanged now and then .i have to restart again
  19. G_Muralidhar_A_XgKc
  20. kalyan soni
