625
  1. mdsafiq
    Cupcake Feb 12, 2019
    mdsafiq , Feb 12, 2019 :
    Sir/Madam,
    I have using One plus 5T .So i have updated This version in my phone.after towards coming wify issue .That problem was *wify connected but no internet. Anybody can tell me how to solve this problem.
  2. KetanParmar
    Eclair Feb 12, 2019
    KetanParmar , Feb 12, 2019 :
    after the update and roughly a week usage I am very clear to come to an conclusion that updating the slows it down and etc problems...
    After updating and use of a week faced following changes:
    1. overall phone performance is slower than earlier
    2. my phone has started hanging and this happened to me more than 2 times. YOU CAN CHECK ATTACHED PHOTOGRAPH FOR REFERENCE as it show half the screen only as at that point Phone was hanged
    3. unnecessary storage us getting uses
    PS: somehow not able to attach Photographs as app not giving option to select screenshot from inside the phone
    Major Rager and N1524300102050 like this.
  3. D1550003945982
    D1550003945982 , Feb 12, 2019 :
    My phone has become most unstable after this upgrade. every thing is crashing and closing. cannot switch WiFi smoothly, have turn off and then on wifi. Google assistance is not working on my voice command.
    SudebCena likes this.
  4. akoplus6
    Cupcake Feb 13, 2019
    akoplus6 , Feb 13, 2019 :
    post getting the update my phone is not ringing.its fixed on vibration mode
  5. N1524300102050
    Donut Feb 13, 2019
  6. selva05
  7. jlmfrance76
    Donut Feb 13, 2019
    jlmfrance76 , Feb 13, 2019 :
    yes, I finally did (waited a Month to get a stable Pie version)
    No problem at all, actually just cosmetic changes, no Big deal.
    Ah but the battery seems to last twice as long !!!
    Shadink likes this.
  8. akoplus6
    guys can any one help.
    received the update yesterday....post update the phone does not ring. it has gone into vibration mode but does not vibrate either. Any solutions out there?
  9. E1520415845069
    Donut Feb 13, 2019
    E1520415845069 , Feb 13, 2019 :
    my battery is showing Full in 97% of charge.
    and is anyone know how to enable auto call pickup in OnePlus 5t ?
    thanks ..
  10. luciano75
    Eclair Feb 13, 2019
    luciano75 , Feb 13, 2019 :
    ieri hanno aggiornato il oneplus 6 e 6t ma il 5 e 5t quando li aggiornano..... lo sblocco con l' impronta col dito parecchie volte non la prende.
  11. Chirag Jhavar 1617
    Donut Feb 13, 2019
    Chirag Jhavar 1617 , Feb 13, 2019 :
    Is there any update coming after this update as this update is not up to the mark for One plus 5 users.The software has slowed the device and getting it hanged now and then.So is one plus team doing something for the One plus 5 user or sitting around ideal and just reading this kind of comments and keep ignoring as all do.
  12. Nilesh Nalamwar
    Gingerbread Feb 13, 2019
    Nilesh Nalamwar , Feb 13, 2019 :
    Yes go in Settings > Buttons and Guestures > Quick Guestures > Answer call by Guesture
    E1520415845069 likes this.
  13. 005shubham
    Froyo Feb 13, 2019
    005shubham , Feb 13, 2019 :
    is it me or anyone of you noticed that occasionally the animations on OnePlus 5 after android 9 update are a bit choppy and sluggish especially when switching between apps in multitasking tray.?!
    i have already tried wiping cache several times but it didn't help.
    Major Rager likes this.
  14. J1550078554953
    J1550078554953 , Feb 13, 2019 :
    My phone is heating up extremely fast after pie update. Sometimes it heats up to extent that I no longer can pick it up as well. Is there a software solution for this ?
  15. Tcat007
    Honeycomb Feb 13, 2019
    Tcat007 , Feb 13, 2019 :
    I'm on 5t, but don't notice that. I do have them set at .5x. You might try that or off.
  16. baiosss
    baiosss , Feb 13, 2019 :
    For me lag issues solved after a wipe data and installed all my apps from the begining to my OP5. Didn't use Titanium backup this time and I think it's fine now. Also I use "π" kernel from xda and maybe that helped too.
    Pascalcestmoi25 likes this.
  17. O1550089106424
  18. Aziz_Amin_Oneplus
    Jelly Bean Feb 13, 2019
    Aziz_Amin_Oneplus , Feb 13, 2019 :
    Everything is working fine accept that Adaptive brightness, its not learning my way of using brightness of my phone mainly in daylight situations, so I need that open beta 23 Adaptive brightness control which is working flawlessly for the next stable version as it is working great.
    ruijmeira likes this.
  19. MrTalon
    MrTalon , Feb 13, 2019 :
    hello guys just have an question.
    my phone the speed drops sometimes, it's hard lagging and don't know how to fix it?
    do you guys have any solution for this? :)
  20. ErynOP
    ErynOP , Feb 13, 2019 :
    Hello,
    Could you please try to go to your Settings > Developer Options > Find "Disable HW overlays" and enable it.
    Let me know if it changes something.
    Qwert Luiop and MrTalon like this.
