625
  1. Cervantes
    Lollipop Moderator Feb 16, 2019
    Cervantes , Feb 16, 2019 :
    Hi
    The update thread is a thread of questions and/or commentary
    Please, read the first and third post
    https://forums.oneplus.com/threads/oxygenos-9-0-3-hot-fix-ota-for-oneplus-5-and-oneplus-5t.975880/
    Thread merged
  2. Sandeep Tomar
    Cupcake Feb 16, 2019
    Sandeep Tomar , Feb 16, 2019 :
    it's the 5th time I am raising it in forum however one plus doesn't seems to be moving.
    not able to take calls via wired earphones.
  3. farazk3
    Gingerbread Feb 16, 2019
  4. sishu05
    sishu05 , Feb 16, 2019 :
    Hey, after upgrade to 9.0.3 my mobile hangs during call and sometime during pick up. Anyone faced the same issue ??
  5. Aziz_Amin_Oneplus
    Jelly Bean Feb 16, 2019
  6. sow_me
    Eclair Feb 16, 2019
    sow_me , Feb 16, 2019 :
    Hi, can anybody suggest me whether to update or not.? I am really confused, recently I had motherboard problems too. is it good to update now? also my warranty expired so I am reluctant to upgrade.
    Please suggest.! thanks in advance!!
  7. Ismet kjerimi
    Froyo Feb 16, 2019
    Ismet kjerimi , Feb 16, 2019 :
    same here, even wifi connection in not stable, deep.sleep of the fingerprit sensor I hate that, battery draining etc,.They are firced us to buy a new onpelus phone with these buggs
  8. kirthirajan
    Froyo Feb 16, 2019
    kirthirajan , Feb 16, 2019 :
    after this update, I'm facing big time issue with the battery and the mobile gets hung up very often in a single day. this update has made me carry the phone's charger along everywhere :( bugs are just all over the phone.
  9. Paul_W_
    Honeycomb Feb 16, 2019
    Paul_W_ , Feb 16, 2019 :
    Read all the comments here and make your mind up. Personally, I'm staying on Oreo for now.
    H1524754243350 likes this.
  10. tungst5n
    tungst5n , Feb 16, 2019 :
    I've noticed that the volume and brightness are kind of week compared to OxygenOS 8. I have the same keep it to max volume and max before brightness more often than I would have with OS 8. Can anyone else confirm this experience or something approximating that?
  11. PokiX
    PokiX , Feb 16, 2019 :
    tungst5n
    I've noticed that the volume and brightness are kind of week compared to OxygenOS 8. I have the same keep it to max volume and max before brightness more often than I would have with OS 8. Can anyone else confirm this experience or something approximating that?​
    The brightness scaling is now logarithmic while before it was linear so yes, slider needs to be put differently as before for same result.
    Regarding volume, can't remember how it was before.
    Anyway these are sliders, made to be moved so I don't see a problem if you just have to move them differently.
  12. Areebanwar
    Areebanwar , Feb 16, 2019 :
    I find the volume hit to be true. The brightness is differently controlled but is the same.
  13. Trevor.Hawkes
    Ice Cream Sandwich Feb 16, 2019
    Trevor.Hawkes , Feb 16, 2019 :
    If your phone is working and you are happy with it stay with what you've got.
  14. joncharmed93
    NahbiCris likes this.
  15. Aziz_Amin_Oneplus
    Aziz_Amin_Oneplus , Feb 16, 2019 :
    They will don't worry bro.
  16. ErynOP
    ErynOP , Feb 16, 2019 :
    Go to the developer option and enable " disable HW overlays" lags disappeared for me .
  17. A1548514354542
    Cupcake Feb 17, 2019
    faqir.m.abdullah likes this.
  18. G_Dishant_Vora_eKps
    G_Dishant_Vora_eKps , Feb 17, 2019 :
    The fingerprint doesn't work many times and lock screen just freezes out, everytime i have to restart the phone for getting back to normal. Anyone else phasing the same issue??
    Y1518952988605 likes this.
  19. Aziz_Amin_Oneplus
    Jelly Bean Feb 17, 2019
    Aziz_Amin_Oneplus , Feb 17, 2019 :
    Let's see but that HW overlays take much battery if enabled.
  20. hsy78
    Eclair Feb 17, 2019
    hsy78 , Feb 17, 2019 :
    I'm using OOS 9.0.3 for OP5T and no bugs most of the time. I just had a few UI crashes but it stopped. Random freeze 1 time but it's gone. My real issue is the game mode when it randomly stops blocking notifications. It forces me to leave the game and come back in.
    G_Mister_thakur_WmDP likes this.
