624
  1. NahbiCris
    Ice Cream Sandwich Feb 18, 2019
    NahbiCris , Feb 18, 2019 :
    do a data Factory Reset, this probably will fix this problems except for the auto brightness, for that read the second comment in this thread
  2. ruijmeira
    Gingerbread Feb 18, 2019
    ruijmeira , Feb 18, 2019 :
    If you restored a backup (apps most importantly) that you made when still on Oreo or even after on Pie (cache and app data will be the same), that will wield the same result. If you've experienced problems,you should start completly fresh, that is, downloading all your apps from play store again. I know it's a pain, but it's the best option that you've got at the time. Nothing will assure you that 9.0.4 will solve your issues (and how OnePlus updates have been, you should also be worried if you'll ever get the update in a timely manner).
  3. Rahul royy
    Donut Feb 18, 2019
    Rahul royy , Feb 18, 2019 :
    while playing pubg my phone gets hot (even on lowest sittings) . it doesn't happen when I m Android 'O' .. is there any up date comming plz help [e]1f625[/e] any one faceing same problem ..... I was just thinking about rolling back to Oreo but I should give my one plus 5 a little time [e]1f60a[/e]
    sachinsankh likes this.
  4. C1550409403024
    Cupcake Feb 18, 2019
  5. C1523300730750
    Donut Feb 18, 2019
    C1523300730750 , Feb 18, 2019 :
    There is something wrong with the fingerprint. It doesn't work sometimes. when this happens double tap option too doesnt work. It's only after I press the power button the fingerprint and the double top start working. I hope it gets fixed in the future updates. This is the only problem I have faced till now. Everything else seems to be fine.
    pankajsonawane05 likes this.
  6. E1550473100734
    E1550473100734 , Feb 18, 2019 :
    after the latest update, my mobile phone is having trouble playing online games. control on the screen is not as smooth as before and always stuck suddenly. it also lagging sometimes.
  7. H1517829016738
  8. G_Anup_Ram_NOpf
    G_Anup_Ram_NOpf , Feb 18, 2019 :
    after the update, now my phone's display goes off everytime I press the lock button. I possibly can't keep it unlocked 24*7. please help
  9. Kum1r
    Eclair Feb 18, 2019
    Kum1r , Feb 18, 2019 :
    still finder sensor opening have issue after the longtime of sleep mode, display not opening
    Pascalcestmoi25 likes this.
  10. Kum1r
    Eclair Feb 18, 2019
  11. pankajsonawane05
    pankajsonawane05 , Feb 18, 2019 :
    hi, I am facing lot of problems on my 5Tbpost the latest system updates.
    the finger scanner sleeps and do not turns on the phone if ai touch the scanner. I have to click the power button to start the phone
    also, my incoming calls are creating problem. I cannot hear the person once I receive the inconveniences in phone.
    not sure why is this happening.
    please help sort this issue out
    Regards,
    Pankaj
  12. pankajsonawane05
    same with me and also after receiving incoming call I cannot hear the person talking
  13. F_Purush_Reddy_TdkL
  14. sachkharb
    sachkharb , Feb 18, 2019 :
    Where is your 9.0.4?? Lol
    Ujwal hs likes this.
  15. RakeshZn
  16. Ujwal hs
    Donut Feb 18, 2019
    Ujwal hs , Feb 18, 2019 :
    no bro we won't get any information till official announcement from manu j
  17. Trevor.Hawkes
    Trevor.Hawkes , Feb 18, 2019 :
    Are you pressing the power on\off button. If you are what is it you expect to happen.
  18. Kunjantrivedi
    Kunjantrivedi , Feb 18, 2019 :
    Hi, after updated it...system storage become 41 gb...now how to reduce it ?
  19. Hj2396
    Donut Feb 18, 2019
    Hj2396 , Feb 18, 2019 :
    just turn off the sleep optimization from the advanced optimization tab go to settings battery then click on battery optimization then click the three dots on the top right now you will get the advance optimization tab. just turn that off everything will be fine
  20. Hj2396
    Donut Feb 18, 2019
