625
  1. ErynOP
    Gingerbread Feb 21, 2019
    ErynOP , Feb 21, 2019 :
    Weird because this option works immediatly.
  2. TiborPino
    Eclair Feb 21, 2019
    TiborPino , Feb 21, 2019 :
    Also tried disable he layers but nothing changed. Animation in app switcher are very laggy. I'm very disappointed. Phone is one year old but animation performance is terrible.
    Please fix this.
    Major Rager likes this.
  3. NahbiCris
    Jelly Bean Feb 21, 2019
    NahbiCris , Feb 21, 2019 :
    wait in the feedback section are already some reports With this problem accepted as a bug they will fix it soon, if you want to help enter in the feedback section and make a bit report with logs.
    Major Rager and TiborPino like this.
  4. bart877ie
    Honeycomb Feb 21, 2019
    bart877ie , Feb 21, 2019 :
    howdy, I am running 9.0.3 on my OnePlus 5, for three weeks now, moved over from Beta 25 as it was too problematic for daily usage.
    Needles to say, I installed over BETA, cleaned all the settings, without wiping internal storage.
    Phone is running smooth, very good battery life, noticeable improvement to Oreo.
    I haven't noticed any disturbing issues so far.
    Hj2396 likes this.
  5. valentin.n
    Cupcake Feb 22, 2019
    valentin.n , Feb 22, 2019 :
    since a few days i cant install or update apps via play store. when i click update or install it just shows "download pending".
    on my second op5 i still cant turn wifi on!!! anybody has this problem?
  6. maortrol
    Honeycomb Feb 22, 2019
    maortrol , Feb 22, 2019 :
    Try to update to the latest version of Google Play Store.
    And then, wipe cache for that app, and try again.
  7. valentin.n
    thanks for the input. tried it already didnt worked.
    i did the clear storage of play store app and now it is working!
    any solution for not working wifi?
    since 9.0.3 upgrade i cant turn wifi on.
    when i turn wifi on via slider it automaticly turns off after a few second.
    same when i do it via pull down menu.
  8. G1515434784781
    G1515434784781 , Feb 22, 2019 :
    One plus 5t 128gb
    9.0.3 sürümü yükledim...
    Aşağıdaki sıkıntıları tespit ettim...
    Bluetooth kulaklık bağlı iken telefon görüşmesi esnasında hoparlörden konuşmaya devam etmek istediğinde karşı tarafa ses gitmiyor...
    ya da telefon Bluetooth kulaklığa bağlı iken hoporlerden arama yapmak istediğinde karşı tarafa ses gitmiyor.
    Rehbere girdiğimde goruntulenecek rehber seçeneğinden telefon yada Gmail hesabından biri seçilmiş olsa bile arama yapmak için açılır tuşlara bastığımda rehberde aynı kişi bir kaç kere kayıt olmuş gibi gözüküyor (örneğin babam yazan kaydı aramak için 22226 tuşlarına bastığımda babam kaydından bir kaç tane olduğunu gördüm)
    Rehberi komple silip sadece gmail aktif ediyorum ancak aynı anda WhatsApp kişileri listede gözüküyor (aynı kişi iki defa kayıt edilmiş gibi)
    Uygulamalara alarm yada zil sesi eklemek istediğimde depolama alanındaki bir ses (mp3 vs. ) eklemek istediğimde sistem harici sesi eklemeyemedi gibi bir uyarı veriyor...
    ön kamera portre modu seçiyorum ancak normal çekim yapıyor (arka kamera gibi derinlik etkisi oluşmuyor)
    Yeni kurulan uygulamalar ekrandaki boşluklara otomatik kısayol olarak eklenmiyor, yüklediğin uygulamanın kisayolunu seçip ekranlara ekleyebiliyoruz...
    Şarj normalde en ez 6 saat sürüyordu güncelleme sonrasında 4 saat civarı gidiyor.
    Parmak izi bazen algılamıyor uyku moduna alıyor sanki kendini ve o sürede parmak izi algılamıyor...
    Google müzik uygulamasında kilit ekranında albüm kapağını göster seçeneği iptal ettiğim halde dinlediğim müzigin albüm kapağı kilit ekranında gözüküyor.
    Alarm çalmaya başladığında ses kısma tuşlarına bastığımda alarm sessize almıyor...
    Arama kaydetme programları ile
    Bluetooth kulaklık ile yapılan görüşmelerde arama kaydı yapıyor ancak karşı tarafın sesi gelmiyor...
    Sanki kendi kendime konuşuyor gibi kayıt yapıyor..
    Farklı uygulamalar kurdum hepsi aynı..
    Farklı telefonda denedim onda sıkıntı olmadı...
    Bizim Bluetooth ile ilgili yazılım sorunlu sanki..
    Belli aralıklarla bağlantı kesiliyor...
    Mod Edit by Funk Wizard: Translation Added
    One plus 5t 128gb
    I have installed version 9.0.3 ...
    I've identified the following problems ...
    When the Bluetooth headset is connected, when the speaker wants to continue to talk from the speaker during the call, there is no sound to the other party.
    or when the phone is connected to the Bluetooth headset, when the caller wants to make a call, there is no sound to the other party.
    The same person appears to have registered several times when I press the keys to make a call even if one of the contacts in the phonebook to be displayed is selected from the phone or Gmail account.
    I'm just deleting the directory and I'm only activating the gmail, but at the same time the WhatsApp contacts appear in the list (the same person is registered twice)
    When I want to add alarm or ringtone to applications, I want to add a sound (mp3 etc.) in the storage system, the system gives an alert like it could not add external sound ...
    front camera portrait mode but normal shooting (no depth effect like back camera)
    Newly installed applications are not added as automatic shortcuts on the screen, we can select the shortcut of the application you are installing and add to the screens ...
    Charging normally lasted for at least 6 hours, 4 hours after the update goes.
    The fingerprint sometimes does not detect itself as if he is taking sleep and he does not detect fingerprints in time ...
    While I've canceled the Show album art on lock screen in Google music app, the album's album cover appears on the lock screen.
    The alarm does not mute when I press the volume buttons when the alarm sounds.
    With call recording programs
    Bluetooth headset calls with the call recording, but the other party's voice is not coming ...
    It's like he's talking to myself.
    I have set up different applications all the same ..
    I've tried it on different phones, it didn't bother ...
    As if our Bluetooth-related software is problematic ..
    Disconnecting at certain intervals ...
  9. needa
    needa , Feb 22, 2019 :
    I SOOOOOOO wish that I had not updated to Pie. It's so bad. Maybe I will make use of this rainy day and go back. I sure do hate to lose everything.
    Paul_W_ likes this.
  10. DMX72
    Gingerbread Feb 23, 2019
    DMX72 , Feb 23, 2019 :
    Still not managed to get the Google assistant to listen as the microphone doesn't switch on during either voice training or general attempts so I thought try a different assistant.
    Downloaded Cortana from the play store and works no problems first time so it's definitely not a microphone issue.
    I hope they fix this issue soon as I also have a Google Home and have been unable to voice train since I got the speaker due to this bug!
  11. O1548876813281
    Donut Feb 23, 2019
    O1548876813281 , Feb 23, 2019 :
    same here.
  12. O1548876813281
    Donut Feb 23, 2019
    RakeshZn likes this.
  13. RakeshZn
    doekus likes this.
  14. O1548876813281
    Donut Feb 23, 2019
    I think Oneplus developers switched their company from Oneplus.
  15. O1548876813281
    Donut Feb 23, 2019
    Not only msg box, but also for Camera, Torch, other apps as well.
    F1513524721716 likes this.
  16. Ghauttham
    Cupcake Feb 23, 2019
    Ghauttham , Feb 23, 2019 :
    why ok Google is not working on OnePlus 5t? Tried to rematch the voice but gets an error stating unable to access the mic. Any solutions? please.
  17. nick_k
    nick_k , Feb 23, 2019 :
    On Google settings, re-enable access to assistant from any screen. It seems that latest Google app update disabled it.
  18. Vivek_1998
  19. O1548876813281
    Donut Feb 23, 2019
    Everybody is posting their problems/issues here. Who sees or takes care of our concerns? Why this forum exists? **** off.
  20. G_Dumitru_Sirbu_mOzS
    G_Dumitru_Sirbu_mOzS , Feb 23, 2019 :
    I have an impression that no one of OnePlus OS developers is looking here, nobody cares about our problems. OnePlus team is busy with brand new OnePlus 7. I suspect that the next update will not fix our big issues. I wish I will be wrong about the next update, and everything will be fixed.
    Paul_W_, TiborPino and O1548876813281 like this.
