625
  1. harshagp
    Donut Jan 2, 2019
  2. dev27530
    Eclair Jan 2, 2019
  3. c0rsa1r
    Cupcake Jan 2, 2019
    c0rsa1r , Jan 2, 2019 :
    sRGB mode is off by default and when I try to turn it on it turns off again automatically.
  4. PiyashP.
    Cupcake Jan 2, 2019
    PiyashP. , Jan 2, 2019 :
    Anyone who has legit used a VPN for the update and has successfully installed (with no bugs) in it.
    Please confirm.
  5. Stealth777
    Gingerbread Jan 2, 2019
    Stealth777 , Jan 2, 2019 :
    I noticed that about 5 days ago, could not get it to stay on either. let me know if you figure it out.
  6. G_Vivek_Gulia_kHGC
  7. Azhar.01
    Froyo Jan 2, 2019
    Azhar.01 , Jan 2, 2019 :
    when did this happened.. your just making this up.. there's no such ruling in India
  8. dev27530
    Eclair Jan 2, 2019
  9. Viknp
    Cupcake Jan 2, 2019
  10. akshayvaji
    Froyo Jan 2, 2019
    Sunil_Kumar_Kulkarni likes this.
  11. dev27530
    Eclair Jan 2, 2019
    dev27530 , Jan 2, 2019 :
    no vpn work for me tried with several app but failed after installing oxygen updater its successful.
  12. Immu9868
    Cupcake Jan 2, 2019
    Immu9868 , Jan 2, 2019 :
    how to move file in root directory
  13. prasad_s_h
    Cupcake Jan 2, 2019
  14. dev27530
    Eclair Jan 2, 2019
    just go to file manager and move the same on root directory then go to system update section and try to local upgrade
  15. U1546270014396
    Cupcake Jan 2, 2019
  16. prasad_s_h
    Cupcake Jan 2, 2019
  17. dev27530
    Eclair Jan 2, 2019
    please install oxygen update from Play Store I am go to it setting check on partial update
  18. dev27530
    Eclair Jan 2, 2019
  19. Rakesh_Kumar_T
    Jelly Bean Jan 2, 2019
    Rakesh_Kumar_T , Jan 2, 2019 :
    it's safe , but there may or may not be issues , since you care about stability, I recommend you should wait for the update in your device
    Nbrewer92 likes this.
  20. dev27530
    Eclair Jan 2, 2019
