625
  1. Anand PM
    Honeycomb Feb 24, 2019
    Anand PM , Feb 24, 2019 :
    Pie is not stable as of now!!! Atleast for Oneplus 5.
    There is Lags/Frame Drops and Some Glitches.
    doekus and prathamesh24 like this.
  2. Anand PM
    Actually there is issues and many have posted the same thing about lag and frame drops in Feedback Page. Either you got lucky or you haven't reached the point when you get to notice the issues.
  3. Anand PM
    Same here :(
    Romanelo likes this.
  4. G_Colin_Dodds_cIwC
    Ice Cream Sandwich Feb 24, 2019
    G_Colin_Dodds_cIwC , Feb 24, 2019 :
    tell you one problem I have when I text someone I get a ringing sound after the text it's like it's trying to call someone
  5. DNS2002
    Eclair Feb 24, 2019
    DNS2002 , Feb 24, 2019 :
    I do felt some lag, but they went away on their own, perhaps OS is improving memory management in the background. Now its butter smooth.
    My personal opinion is not to wipe cache as they do have your pattens of usage.
    Even my camera shutter sound can be switch off though im not comfortable without the sound.
  6. suhaib kazi
    Eclair Feb 24, 2019
    suhaib kazi , Feb 24, 2019 :
    in gaming mode if it's on blocked notification setting it still shows the notification but if it's on heads up only then it's as it should be that is heads up
    maybe suggest me what i might be doing wrong
    or fix it
    OnePlus 5t
  7. Qwert Luiop
    Froyo Feb 24, 2019
    Qwert Luiop , Feb 24, 2019 :
    I'm on this version for 5T. Since yesterday, my MTN number can't make calls. It hangs up whenever I try. I switched SIMs but it's still same. I removed it to another phone (Techno J7) and it's working fine. What could be the problem? Kindly help me out because I'm missing on some important calls I should've made by now.
  8. J1537868186886
    Cupcake Feb 24, 2019
  9. J1537868186886
  10. Amin.o.s
    Eclair Feb 24, 2019
  11. micharu
    Gingerbread Feb 24, 2019
    micharu , Feb 24, 2019 :
    ok after few weeks i have to say this update made OnePlus 5t 8gb/128gb feels lagy and really slow for phone with 8gb of ram and even after i turned off all battery saving options fingerprint sensor feels slow and unresponsive even if i try to use it right away the display turn off (after 1 minute)
    and i am not even started to talk about the ram management when the phone does not able to keep 4 apps in memory ( fgo na, fgo jp, chrome and discord) and have to reload them when i switch between them
    maqsood2k7 and Qwert Luiop like this.
  12. Nicu2
    Donut Feb 24, 2019
    Nicu2 , Feb 24, 2019 :
    Hi!
    From the last update you have released, one problem was addressed to - fix bluetoth connectivity with the car. But after the update I can't hear nothing on the Bluetooth connection with the car, and it says it is connected. I deleted the device from phone and redone the pair with the car, but without success. It says it is connected on the car but i cant hear something. (i have the One plus 5t, 128gb version)
    Before the update it was working...
    Please fix this issue...
    And another problem is the instability of the gps module, it is one of the weekest from the all the phones I have used, and I am thinking to sale the phone and move to another brand... sory...
    I wait 5 minutes and reboot 2 times when I was in the car to conect the Gps to the satelites.
  13. G_Michał_L_VJCp
    G_Michał_L_VJCp , Feb 24, 2019 :
    I'll wait for the update, disabling feature is not the solution to the problem. It's like suggesting turning off a computer if you have a problem with it...
    1. You'll experience this, it's a matter of time. It's random, it doesn't have to be after longer stand-by. Just wait for it :D
    2. Same
    3. Battery is even better on Pie, imho
    4. App crashes, these not Pie ready. If you don't use these kinda apps, you may not have the problem. But it's not Oxygen related, anyways, so we have to wait for Pie updates on certain apps and still it's not guaranteed that they will work fine after 1st update.
    5. You are not using incompatible apps, check point 4.
    6. Adaptive brightness works fine but not from the start. It takes some time to settle.
    OnePlus can't really make it compatible with every single car. It may be car related also. Hard to say. Check if your car can work with Android Pie, in the first place.
    When it comes to GPS, not true at all. This is the best GPS I've ever had so far. And I drive a car a LOT. In around a year and 3 months I've had maybe 2 times when Google Maps stopped locating me. It's hard to say if it was GPS related or app related (I'm Google Maps beta tester so I'm always at beta). It's still so rare that it doesn't really matter. Relaunching google maps solved it. Apart from that, gps works really fast, it's ready instantly after opening gps app, reliable which is staying connected on a few hundreds km trip and is really strong meaning it can localize inside buildings sometimes. It also connects to lots of satellites at once. The most I've ever seen on a phone. So about the GPS, you should probably change the app you use or maybe start thinking that your phone is faulty. GPS worked well since the very beginning through all Android versions: Nougat, Oreo and now Pie. Never had any issues.
  14. Nicu2
    Donut Feb 24, 2019
    Before the update the Bluetooth was working, and after not...
    And for Gps I am using Waze app, rarely Google map. In my country it is better. There is no comparison for interface, detail and real time trafic.
  15. Hj2396
    Eclair Feb 25, 2019
    Hj2396 , Feb 25, 2019 :
    just turn off the sleep optimization not the other one then see how it works i too had the same problem and read comments where i found the solution
  16. needa
    Honeycomb Feb 25, 2019
    needa , Feb 25, 2019 :
    I said/thought the same thing. Give it a week. Then think back to 5.1.7.
    Paul_W_ and Devendra_kamble like this.
  17. Zaphodrocks
    Ice Cream Sandwich Feb 25, 2019
    Zaphodrocks , Feb 25, 2019 :
    Other than the occasional random UI stutter, Pie has been great so far. Battery life is much better than Oreo and the phone is fast and fluid. I have not experienced any fingerprint issues after the first day and no app crashes so far. No bluetooth or GPS issues either.
    Luis Sismeiro, ruijmeira and danycmoi like this.
  18. LeGaspi
    Cupcake Feb 25, 2019
    LeGaspi , Feb 25, 2019 :
    hi,
    Since yesterday, the bluetooth if my OP5T refused to be turned on.
    Sometimes, it seems to be working , but no bluetooth symbol on the top right corner of the phone and i can't connect anything to it.
    i can't find informations on the net about a knowned problem.
    i have reset Factory the phone, but nothing changed.
    is the bluetooth dead or is it a software problem?
    thx
  19. Bogo268
    Gingerbread Feb 25, 2019
    Bogo268 , Feb 25, 2019 :
    In Android 9, BT symbol is showned only when you are connected with an device.
    W1523980290575 likes this.
  20. N1521390280945
    N1521390280945 , Feb 25, 2019 :
    Post the update I have started facing issues related apps not responding . Battery starts draining all of a sudden
