625
  1. G_Kanaka_Gunatilake_GYin
    Cupcake May 4, 2019
    G_Kanaka_Gunatilake_GYin , May 4, 2019 :
    I reported a bug but it is not fixed with latest update. However now when I select vibrate from the slider and a call received from SIM 1 it only vibrates. However when a call receives feom SIM 2 it rings and vibrate. Now the problem swapped from SIM 1 to SIM 2 instead of fixing it.
  2. Waveform Modifier
    Marshmallow May 4, 2019
    Waveform Modifier , May 4, 2019 :
    This is an old thread and this forum is also not a bug report site.
  3. sean_peter
    Cupcake May 7, 2019
    sean_peter , May 7, 2019 :
    Alert Slider : Switches from Ring to Silent automatically.. Back and forward.
    Please Assist.. How can I fix this issue?
    Thanks
  4. Surya Manikyam
    Gingerbread May 27, 2019
    Surya Manikyam , May 27, 2019 :
    Guys..had a Small problem with my OnePlus 5...i had a habbit of put off notifications of apps which i feel were unnecessary.....but recently i had an issue with my notifications
    notification sound was coming and there was no notification appearing on my screen...i cant understand whats the problem...plz help
  5. N1519816730414
    Donut Jul 4, 2019
    N1519816730414 , Jul 4, 2019 :
    Actually my problem was solved with the new Instagram update thanks
  6. Vivek_1998
    Cupcake Aug 2, 2019
  7. Meetbhanushali@
    Cupcake Nov 3, 2019
  8. Meetbhanushali@
    Cupcake Nov 3, 2019
    Meetbhanushali@ , Nov 3, 2019 :
    Wipe cache will just erase the cache, waste and unnecessary part in the OnePlus device.
    Here are the steps:
    1. Power off the device and press the volume down and power buttons simultaneously for 15-20 seconds
    2. Select the Language as "English"
    3. The recovery screen will appear on the display
    4. Select "Wipe data & cache"
    5. You will have three options stating “Reset system settings”, “Erase everything” and “Wipe cache”
    6. Select "Wipe cache”
    7. Select “Yes”
    8. Select "Reboot"
  9. E1572800768339
    Cupcake Nov 3, 2019
  10. Waveform Modifier
    Marshmallow Nov 3, 2019
    Waveform Modifier , Nov 3, 2019 :
    Why are you digging up old threads to provide something that is literally everywhere on this forum?
  11. Waveform Modifier
    Read announcements forum
  12. S1515584308885
    Cupcake Mar 15, 2020
  13. Waveform Modifier
    Marshmallow Mar 15, 2020
    Waveform Modifier , Mar 15, 2020 :
    Why are you digging up old thread for no reason while your questions should be directed to the pinned update thread?
  14. vasanth88j
    Froyo Mar 17, 2020
    vasanth88j , via OnePlus 5T , Mar 17, 2020 :
    use oxygen updater , select incremental update and you are done. download and install. cheers
    Aravind︿949 and Danielarr45 like this.
  15. Danielarr45
    Honeycomb Mar 18, 2020
  16. I1552067422671
    Cupcake Mar 26, 2020
    I1552067422671 , Mar 26, 2020 :
    Hello dear Can you please help me out I am using one plus 5t since from last week I am not able to receive any messages and I think it's Sim card issue but i used in other mobile its works fine but in this mobile it doesn't work so it's my humble request to you kindly help me out in this issue your early reply will be highly appreciated
  17. Waveform Modifier
    Marshmallow Mar 26, 2020
    Waveform Modifier , Mar 26, 2020 :
    The community humbly request you not to use an old outdated thread but use the latest update thread instead.
  18. Z1547606705278
    Cupcake May 1, 2020
  19. Aravind︿949
    Cupcake May 2, 2020
  20. Ashwanth Ram
    Donut May 14, 2020
