625
  1. eternaldreams
    Ice Cream Sandwich Jan 2, 2019
    eternaldreams , Jan 2, 2019 :
    1 your country law, in my country is allowed and i can disable sound
    3 Android Pie issue
  2. W1508519642813
    Cupcake Jan 2, 2019
    David_2293 likes this.
  3. alex030200
    Donut Jan 2, 2019
    alex030200 , Jan 2, 2019 :
    Main stage isn't started yet, only little part of devices receiving update now, even through VPN. If you don't want to wait, you're able to download update by Oxygen Updater or from official server by yourself.
  4. miromir2217
    Cupcake Jan 2, 2019
    miromir2217 , Jan 2, 2019 :
    Is the update in different countries the same or there are differences, like the modem used for the package depending on the region?
  5. alex030200
    Donut Jan 2, 2019
    No, Oxygen is international and update file is similar everywhere. Even the modem depends only on version of Oxygen
    miromir2217 likes this.
  6. shriman_shubham_g
    Froyo Jan 2, 2019
    shriman_shubham_g , Jan 2, 2019 :
    Thanks for the information, but the provided link is not secured and this is my point! Why should the user wait! Why is the OTA roll outs are not reaching to all the devices!
    OnePlus should give some attention to this.
    Nbrewer92 and afrose111 like this.
  7. N1546071271981
    Cupcake Jan 2, 2019
    N1546071271981 , Jan 2, 2019 :
    Yes WHY?
    It's horrible, and no way to customise it to The way it was!?!?
    Please, change it Back [e]1f62a[/e]
  8. chrisch852
    Cupcake Jan 2, 2019
    chrisch852 , Jan 2, 2019 :
    I am not able to stream audio via usb to my cars hifi. On oreo it worked with plug an play. What i tried:
    -official pioneer app
    -usb otg to have access to internal storage like usb
    -developer options: disable usb-audiorouting
    -another usb cable
    Does someone have another idea?
  9. Aziz_Amin_Oneplus
    Jelly Bean Jan 2, 2019
    Aziz_Amin_Oneplus , Jan 2, 2019 :
    Once again I have to say Oneplus is not Samsung nor Apple, they go according to limit not the masses, it will take time to reach that status.
  10. Mr_Cyrox
    KitKat Jan 2, 2019
    Mr_Cyrox , Jan 2, 2019 :
    2 reasons:
    Server overload and in case critical bugs are found while the rollout is going on just like what happened with OxygenOS 9.0.0...
  11. shriman_shubham_g
    Froyo Jan 2, 2019
    Agreed. But, now it is not that small startup that has small customer count it IS now a Brand in the market. It is the high time that OnePlus should think about their OTA update reachability. As a user, even I dont like this since I have not received any OTA update after 5.1.7.
    Nbrewer92 likes this.
  12. Mr_Cyrox
    KitKat Jan 2, 2019
    It will remain vertical as this is part of Google's design choice in Pie...
    Why?
    Because OxygenOS is about stock Android with a few useful features and customization options...
    I doubt they change it back...
  13. Aziz_Amin_Oneplus
    They will soon when they will try to make more than 10 phones in an year, this is just a start for them and they have just started it out with a small budget 5 years ago, it takes years and years and Oneplus also feel for users need to give them update all in one go but that will take time, if you cannot wait try Oxygen updater or VPN.
    shriman_shubham_g likes this.
  14. shriman_shubham_g
    Froyo Jan 2, 2019
    The second reason makes some sense to me but not the first one as they could buy bigger capacity servers.
  15. Mr_Cyrox
    KitKat Jan 2, 2019
    Servers are expensive to buy and can be an annoyance to setup
  16. shriman_shubham_g
    Froyo Jan 2, 2019
    with 1.6 billion of revenue I think they can afford a good server.
  17. F_Aki_Helveranta_YpUP
    Cupcake Jan 2, 2019
    F_Aki_Helveranta_YpUP , Jan 2, 2019 :
    I rather pay what these phone cost now, than start to pay more for some days faster updates. And I know I'm not alone with my opinnion. If you cant wait for update, then work around the problem and use straight download links or updater. (no I'm not here to guide you with that). Highly doubt oneplus wants to cut down % of their win $$$$. Sure there are people posting about not receiving update, but most don't type when they are happy, unsatisfied post..
  18. G_Vrushnil_patel_rApR
    Cupcake Jan 2, 2019
  19. Sanjeev KumarS
    Froyo Jan 2, 2019
    Sanjeev KumarS , Jan 2, 2019 :
    same here too
  20. I1543612145567
    Cupcake Jan 2, 2019
    I1543612145567 , Jan 2, 2019 :
    está actualizacion me jodió el RGB, al ingresar ala galería se cambian los colores, y cada rato mantiene se oscurese la pantalla o se pone cálida creo no solucionaron mucho, tuve que volver a 9.0.0
    is update I ****** the RGB, to enter the gallery the colors are changed, and every time keeps the screen dark or it gets warm I think they did not solve much, I had to go back to 9.0.0
