597
OxygenOS 9.0.3 OTA for OnePlus 6
  1. cyberman_5145
    Gingerbread Feb 9, 2019
    cyberman_5145 , Feb 9, 2019 :
    looks like wifi usage is kill battery badly even on Oreo. Pie/Oreo both seem to have this issue with notification delay, battery drain. this is once I updated to pie and then rolled back to Oreo.
  2. Trevor.Hawkes
    Ice Cream Sandwich Feb 9, 2019
    Trevor.Hawkes , Feb 9, 2019 :
    Till the solution for this comes out I turned on ambient display. This kicks the screen into life when you lift the phone and the double tap works.
  3. Entr3pr3n3ur
    Froyo Feb 9, 2019
  4. drl431
    Community Hero 2020 Feb 9, 2019
    drl431 , Feb 9, 2019 :
    Yes, about every 2 months, like the 5T.
  5. Entr3pr3n3ur
    Froyo Feb 9, 2019
    Entr3pr3n3ur , Feb 9, 2019 :
    That's really cool. :)
    Eagerly waiting to get my hands on it.
    drl431 likes this.
  6. cyberman_5145
    alphallama
    any hope of seeing a fix for the 6t tap to wake not working.i have seen a few 6t users saying their phones goes into a deep sleep like mine does and the tap to wake feature stops working ? the feature works if you have just gone into screen off.But if you leave it for a longer period of time the feature stops working​
    have you checked if battery optimization settings are turned off? this doesn't give me any such trouble on my OP6 as well OP6T which I own.
    the settings below sits under settings >> battery >> battery optimization >> click 3 dots on right too to enter the below screen. see this.
  7. Arpit01
    Froyo Feb 9, 2019
    Arpit01 , Feb 9, 2019 :
    issues:
    - notification on apps (dot over app icon) doesnt disappear even after checking the notification on that particular app.
    - Airtel network voice call waiting option not happening.
    please fix these with next update
  8. Leo Biglia
    Cupcake Feb 9, 2019
    Leo Biglia , Feb 9, 2019 :
    Guys, in the 9.0.3 I've noticed a few lags in the animations like sometimes opening apps and multitasking, i don't know what it Is. Hope it will solve in a next update.
  9. Artemus.
    Artemus. , Feb 9, 2019 :
    Have you changed the animation speeds in Dev Options?
  10. Leo Biglia
    Cupcake Feb 9, 2019
    Never did it
  11. Artemus.
    That's your answer. Enable Dev Options by tapping the Build Number in About 7 times, go back, Utilities > Developer Options. Look for the animation settings (there's three) then change them all to 0.5x.
  12. Leo Biglia
    Cupcake Feb 9, 2019
    Ok I try it, thank u bro
  13. G1549762460506
    Cupcake Feb 10, 2019
    G1549762460506 , Feb 10, 2019 :
    cellular data not working after upade. Ibjust activated my phone and after update to oxigen 9.0.3 cellular not working. i can recieve viber messages but no internet or any other app (twiter, goigle search...). Any update or solution?
  14. Artemus.
    Community Hero 2020 Feb 10, 2019
    Artemus. , Feb 10, 2019 :
    Reset your APN settings.
  15. G1549762460506
    i wrote about cell databproblem afterbupdate to 9.0.3. i can not connect to internet bia cell internet. only viber works but google search or any other app not working. someone wrote to reser APN setings but here is same problem after reset. i have done reset all network settinhs and after that ib reset pnone. still same problem. any solution?
    MSK11 likes this.
  16. G1549762460506
    I tried to switch on SIM 2 and i still have same problem with cell data. Is there any solution or it will be resloved with another update?
  17. G_Sheguey_Sheguey_tNMH
    Froyo Feb 10, 2019
  18. nurhalim88
    Honeycomb Feb 10, 2019
  19. kdw1963
    kdw1963 , Feb 10, 2019 :
    Hi, i use the latest beta version on my 6T but want to go back to stock version, how do i do that?
  20. Dante69
    Froyo Feb 10, 2019
