595
OxygenOS 9.0.3 OTA for OnePlus 6
  1. G1549762460506 Cupcake Feb 10, 2019
    G1549762460506, Feb 10, 2019 :
    I tried to switch on SIM 2 and i still have same problem with cell data. Is there any solution or it will be resloved with another update?
  2. G_Sheguey_Sheguey_tNMH Froyo Feb 10, 2019
  3. nurhalim88 Honeycomb Feb 10, 2019
  4. kdw1963 Cupcake Feb 10, 2019
    kdw1963, Feb 10, 2019 :
    Hi, i use the latest beta version on my 6T but want to go back to stock version, how do i do that?
  5. W1542124766660 Donut Feb 10, 2019
  6. kdw1963 Cupcake Feb 10, 2019
  7. W1542124766660 Donut Feb 10, 2019
  8. drl431 Jelly Bean Feb 10, 2019
    drl431, Feb 10, 2019 :
    2 possibilities:
    You are looking in the wrong settings area.
    Your carrier or sim does not provide option.
    ironass likes this.
  9. Mohammad Faraaz Froyo Feb 10, 2019
    g_castorina likes this.
  10. LegolasX Ice Cream Sandwich Feb 10, 2019
    LegolasX, Feb 10, 2019 :
    you will get March in next month and if oneplus is being $**t they will give feb security patch in early March!!
    like they did with last release...
  11. G1549762460506 Cupcake Feb 10, 2019
    Still having problem with cell data.
    As i said, viber works normal on cell data, notification from this app also working normal. Other app like twiter, gmail, search or any other app dont work.
    I tried network setup reset, APN reset (as you sugested), factory reset, inserted another SIM from different network provider and still same problem.
    In notification bar, by network strenght singnal there is "!".
    Im on Mtel network from Bosnia and Hercegovina, it is a 3G network.
    Do anyone have suggestion or i will have to wait for another update?
  12. Roger.T Ice Cream Sandwich Feb 10, 2019
    Roger.T, Feb 10, 2019 :
    Where is my shoe?
    moniishann24 likes this.
  13. Mohammad Faraaz Froyo Feb 10, 2019
  14. Mohammad Faraaz Froyo Feb 10, 2019
  15. Roger.T Ice Cream Sandwich Feb 10, 2019
  16. R1549001746696 Cupcake Feb 10, 2019
  17. F_Wassim_Al_ihal Gingerbread Feb 10, 2019
  18. T1529654676065 Cupcake Feb 10, 2019
  19. A1548164718247 Cupcake Feb 10, 2019
  20. Mohammad Faraaz Froyo Feb 10, 2019
    Mohammad Faraaz, Feb 10, 2019 :
    If you know about this tell or else be quite
