598
OxygenOS 9.0.3 OTA for OnePlus 6
  1. Yatin_Asri
    Gingerbread Feb 12, 2019
    Yatin_Asri , Feb 12, 2019 :
    what was the update size that u installed? 143MB or 188MB?
  2. chenkamfatt
    Cupcake Feb 12, 2019
    chenkamfatt , Feb 12, 2019 :
    143mb. Does it make a difference?
    Yatin_Asri likes this.
  3. Yatin_Asri
    not sure as I had these 2 different size for my my OP6 devices. I had installed 143mb using VPN Canada last night and this one works like a charm for my device.
    I got same update with package size as 188 this morning for my other device and felt stunned...
    have you tried cache clearing using recovery? if you already have, I guess a FDR(factory data reset) seems to be a last resort before taking it to service centre .....
  4. chenkamfatt
    Hmm yes tried deleting caches... Factory data reset - could try this.
  5. Yatin_Asri
    I know it isn't an easy one to copy data and move it back on however maybe this works.
  6. Jonsnow6099
    Jelly Bean Feb 12, 2019
    Jonsnow6099 , Feb 12, 2019 :
    Native jio video call not working in 9.0.4 on op6 and google duo is just a waste...what a pity update by oneplus specially after the same issue was reported in beta build..
  7. Samuelodan
    Samuelodan , Feb 12, 2019 :
    hmmm, that's a possible factor tho.
  8. Vicky_R_Vicky
  9. Kytharsis
    Marshmallow Feb 12, 2019
    Kytharsis , Feb 12, 2019 :
    No. You realize it has to have the hardware component right?
  10. Ac3theone
    Ac3theone , Feb 12, 2019 :
    I'm still getting random reboots with private DNS turned on after the latest 9.0.4 update
  11. Yatin_Asri
    Gingerbread Feb 13, 2019
    Yatin_Asri , Feb 13, 2019 :
    have you installed full ROM or OTA package? try full factory data reset and clean flash full OOS 9.0.4 ROM and see if that helps.
    if above doesn't work either, service centre is your only resort as per my knowledge
    Kytharsis likes this.
  12. Yatin_Asri
    can't really tell people these days to be careful of what they wish for..... Really people need to be told difference between hardware and software components
  13. Yatin_Asri
    OOS 9.0.4 seems to have heating issue on my device.... tested it for 2 days and it doesn't seem to settle down.
    Rolling back to 9.0.2 as that was the best for pie.....
  14. Mohammad Faraaz
    Froyo Feb 14, 2019
  15. 4sheesh
    Honeycomb Feb 14, 2019
    4sheesh , Feb 14, 2019 :
    cant tell bcoz using OB 12
  16. G_Josvin_SS7
    Froyo Feb 14, 2019
  17. robin143
    robin143 , Feb 14, 2019 :
    9.0.3 is having good battery life . after updating to 9.0.4 , battery life decresed and heating issues.
  18. vj4mqntm
    Froyo Feb 14, 2019
  19. J1532844518029
    Cupcake Feb 15, 2019
  20. AmalenduJena
    AmalenduJena , Feb 15, 2019 :
    I have updated the recent Oxygen OS version, but if I switching to my Vodafone network for internet then the Jio network is automatic disabled.
    Previously I was perfect I was able to use both of network at a time. But there is a bug in this version I think.
    Please help me to find this issue, it is very bad things for OnePlus user that both are having 4G slot but we can use one because of some bug....
