595
OxygenOS 9.0.3 OTA for OnePlus 6
  1. razashakaib Cupcake Mar 6, 2019
  2. G_Josvin_SS7 Froyo Mar 6, 2019
    G_Josvin_SS7, Mar 6, 2019 :
    ooh just clear the cache and storage > Force stop and open again Works always
    razashakaib likes this.
  3. G_Josvin_SS7 Froyo Mar 6, 2019
    if again goes wrong uninstall the updates of phone app and everything will be fixed
  4. razashakaib Cupcake Mar 6, 2019
    razashakaib, Mar 6, 2019 :
    restarted and now it seems to be working fine buddy and the auto call recording stopped successfully thnx for the resolution buddy.[e]270c[/e]️
  5. G_Josvin_SS7 Froyo Mar 6, 2019
    Sorry for blank apk I didn't check the apk version
  6. razashakaib Cupcake Mar 6, 2019
    apk is working just fine the apk u provided has only resolved the issue dear. so don't wrry abt the apk.
    G_Josvin_SS7 likes this.
  7. G_Josvin_SS7 Froyo Mar 7, 2019
    G_Josvin_SS7, Mar 7, 2019 :
    [e]1f60d[/e][e]1f60d[/e][e]1f60d[/e][e]1f60d[/e]
  8. N1539961316860 Donut Mar 27, 2019
  9. B1540645859558 Donut May 8, 2019
    J1532844518029 likes this.
  10. Edee25 Gingerbread May 8, 2019
    Edee25, May 8, 2019 :
    which mobile?
    K1546223066910 likes this.
  11. B1540645859558 Donut May 8, 2019
  12. B1527824037361 Eclair May 8, 2019
    B1527824037361, May 8, 2019 :
    the sun is the problem, since with less sun the brightness is low and therefore less time to dry and hence more time in hanging. Move to equator or more sunlight area.
    Jimmyostrom likes this.
  13. N1533137290994 Donut May 8, 2019
    N1533137290994, May 8, 2019 :
    my one plus 6 mobile heats up very quickly as I start using , what is the problem , it hangs many time,
    venky1470109 likes this.
  14. Rahuldey123 Eclair May 8, 2019
    Rahuldey123, May 8, 2019 :
    clear the cache by pressing power and volume down button together. and also clear from storage on setting.
  15. Edee25 Gingerbread May 8, 2019
    factory reset is the only option... may be software gets crash because of some third party apps...
  16. B1540645859558 Donut May 8, 2019
  17. Edee25 Gingerbread May 8, 2019
    it wont work some time bro I have tried it...
    Rahuldey123 likes this.
  18. B1527824037361 Eclair May 8, 2019
    You must be hot. generally hot people's phone are also hot (due to transfer of heat, law of thermodynamics).
    Kytharsis and dilipkumar2288 like this.
  19. Y1534012279585 Cupcake May 8, 2019
  20. Rahuldey123 Eclair May 8, 2019
    same problem going on with me too.. before the 2 updates it was very smooth and normal. but after i update it starts heating.. before when i use to play pubg it was normal after even i use. but now a days it's getting too much heat.
    there is something issue with the update
    arefinkaosar and N1533137290994 like this.
  21. B1527824037361 Eclair May 8, 2019
    yes the issue with the update is that the phone is now terribly more secure due to security patches.
