598
OxygenOS 9.0.3 OTA for OnePlus 6
  1. N1533137290994 Donut May 8, 2019
    N1533137290994, May 8, 2019 :
    ya bro, bt I dint use any third party apps n pubg bt also heating issue is there
  2. Edee25 Gingerbread May 8, 2019
    Edee25, May 8, 2019 :
    same here bro...they are not fixing that issue...only focussing on their new products and forgetting the old products...
    Rahuldey123 likes this.
  3. boscoks Cupcake May 8, 2019
  4. nazir2671 Cupcake May 8, 2019
    nazir2671, May 8, 2019 :
    some Time without keeping in vibrate mode.it automatically gone in vibrate mode
  5. mihirrana Cupcake May 8, 2019
    mihirrana, May 8, 2019 :
    Rahuldey123
    same problem going on with me too.. before the 2 updates it was very smooth and normal. but after i update it starts heating.. before when i use to play pubg it was normal after even i use. but now a days it's getting too much heat.
    there is something issue with the update​
    this problem was fixed by 1) clear the cache in recovey mode. then 2) also make a full battery cycle from 0 to 100 and then 100 to 0 percent. repeat twice. phone will stop heating. thank me later.
  6. B1527824037361 Froyo May 8, 2019
    B1527824037361, May 8, 2019 :
    Nearly same problem but with my bike. it automatically moves from the position where I last parked it
  7. Rahuldey123 Eclair May 8, 2019
    Rahuldey123, May 8, 2019 :
    yeah bro..
    sometimes without playing once in a whole day still it gets heated.. and also during the call also simply it get heat.
    but i didn't face any kind of lacks of hanging issue. only i face is heating issue.
    N1533137290994 likes this.
  8. Rahuldey123 Eclair May 8, 2019
    bro.
    i have clear cache lots of time. yeah but about the battery you told is i didn't done yet. i will try today.
    thank you.
    R1511070543574 likes this.
  9. O1536035157940 Froyo May 8, 2019
    O1536035157940, May 8, 2019 :
    actually it all started with oxygen os 9
    they slow down 1+6 a lil
    so that they can brag about 6t
    and now when we r in the verge of launch of a new series,
    they have to slow down old devices a lil bit
    its called strategy
    apple use it on all of their updates and charges people money to turn it back to normal
    you should be thankful that they aren't charging you a penny
    and cursing them aswell
    surendra91 likes this.
  10. N1533137290994 Donut May 8, 2019
    I'm facing hanging issue which was not there in the 9.0.2 r 9.0.1 update
  11. Rahuldey123 Eclair May 8, 2019
    for the hanging issue once you can clear cache in a recovery mode. then backup your phone and then reset factory the phone once. i also have tried once and then its going normal
  12. N1533137290994 Donut May 8, 2019
    factory reset ? i hv done it twice
  13. anshulmittal6 Froyo May 8, 2019
  14. O1536035157940 Froyo May 8, 2019
  15. Rahuldey123 Eclair May 8, 2019
    but before that you need to clear the cache in recovery mode as well in storage section. then reboot the phone then factory reset. once you can try and see.. because when i did it works very well. and still its going normal. i didn't face any hang issue still.
  16. N1533137290994 Donut May 8, 2019
    k, today I'll do , thank u bro
  17. Rahuldey123 Eclair May 8, 2019
    you are always welcome bro. [e]1f60a[/e]
  18. F_Atul_Mehrotra_LJMQ Cupcake May 8, 2019
  19. ShindeMohanrao Cupcake May 8, 2019
  20. G1534850069280 Cupcake May 8, 2019
    ShindeMohanrao likes this.
  21. ShindeMohanrao Cupcake May 8, 2019
  22. Edee25 Gingerbread May 8, 2019
    it will heat just play pubg or asphalt 9 for just 10min
