598
OxygenOS 9.0.3 OTA for OnePlus 6
  1. Varun Narayan
    Froyo Dec 30, 2018
    Varun Narayan , Dec 30, 2018 :
    There are a number of free EQ apps on the play store which work with bluetooth earphones/speakers, how do they work?
    I don't use those apps because they come with a lot of ads, most of them aren't reliable and do not work with majority of apps(Youtube for example)
  2. E1528107108904
    Cupcake Dec 30, 2018
    E1528107108904 , Dec 30, 2018 :
    I'm experiencing a slight delay ni face unlock, earlier it was below 1 sec now its taking almost 2 sec to unlock
  3. Kytharsis
    Marshmallow Dec 30, 2018
    Kytharsis , Dec 30, 2018 :
    Case. In. Point. Thank you very much. I suggest root + ViPER if you really want compatibility.
    Varun Narayan likes this.
  4. kokoi612
  5. vishrutkmr7
    Gingerbread Dec 30, 2018
    vishrutkmr7 , Dec 30, 2018 :
    So many features from Beta channels didn't arrive..
    OnePlus Roaming
    Dialer Caller ID
    New UIs for the Phone app..
    Video Enhancements
    Maybe they're still buggy
  6. Varun Narayan
    Froyo Dec 30, 2018
    Kytharsis
    Case. In. Point. Thank you very much. I suggest root + ViPER if you really want compatibility.​
    I rooted my old 3T and messed it up, and none of the bank apps work with root and I just, want my phone to work fine at all times.
    Anyways, thank you for the suggestion, and your time
    dasacom and Kytharsis like this.
  7. H1535106412349
    Donut Dec 30, 2018
  8. Varun Narayan
    Froyo Dec 30, 2018
    Yep exactly, they might require a little more work. Just be patient!
    vishrutkmr7 likes this.
  9. kokoi612
    kokoi612 , Dec 30, 2018 :
    still checking it bro if i found something i will try to post here. [e]1f60a[/e]
  10. Tamzi3
  11. Gameslayer
    Froyo Dec 30, 2018
    Gameslayer , Dec 30, 2018 :
    appreciate always s/w developers but not at all good service from local service stations very few are good and it's like picking needle from grass
  12. Nynesh
    Nynesh , Dec 30, 2018 :
    I have an issue in front facing camera that it is not focusing more persons faces in group photos ..
  13. G_arun_muthu_fnjf
    Eclair Dec 30, 2018
  14. Aman_Mourya
    Donut Dec 30, 2018
    Aman_Mourya , Dec 30, 2018 :
    German in vpn working
  15. 01baftb
    1Dynamitedoml likes this.
  16. Aman_Mourya
    Donut Dec 30, 2018
    01baftb likes this.
  17. Y1539283876987
  18. kaustav_lhri
    kaustav_lhri , Dec 30, 2018 :
    right now I'm on open beta 10.
    should I get the update over the air or I have to do factory reset my phone?
  19. JakovskiFinland
    Honeycomb Dec 30, 2018
    JakovskiFinland , Dec 30, 2018 :
    EQ is for EVERY BLUETOOTH DEVICE.
    There are oneplus wireless codecs, that are designed to get the most out of them.
    Eq and presets are available for every BT devices you have.
    Magnera likes this.
  20. A1535567578018
