598
OxygenOS 9.0.3 OTA for OnePlus 6
  1. Aathif_Mahir Ice Cream Sandwich Dec 30, 2018
  2. R1533288734841 Cupcake Dec 30, 2018
    R1533288734841, Dec 30, 2018 :
    Though after receiving update OTA I updated it. my update log doesn't match with that on the forum. it doesn't show any updates in slow motion videos. also no updates on volte
  3. toureelhadj Froyo Dec 30, 2018
    toureelhadj, Dec 30, 2018 :
    I have a french SIM card, I'm actually in Italy and after this update I can't have 4G in roaming does anyone notice this issue ?
  4. luke82 Cupcake Dec 30, 2018
  5. aidangaller Froyo Dec 30, 2018
  6. Faarr Eclair Dec 30, 2018
  7. sumantakumarskp Cupcake Dec 30, 2018
  8. hearty128b Eclair Dec 30, 2018
    hearty128b, Dec 30, 2018 :
    nice.. I feel you have improved the experience of the full screen gestures thank you very much!
  9. G_OnE_PunCh_wowb Cupcake Dec 30, 2018
  10. Sudarshankarthi Cupcake Dec 30, 2018
    Sudarshankarthi, Dec 30, 2018 :
    Still it doesn't support surround sound for songs and games and nobody knows it! Anybody facing the same problem or its only me..!
  11. Sanket914 Eclair Dec 30, 2018
    Sanket914, Dec 30, 2018 :
    battery life has improved like around 80% as it was in oreo.
    If you are looking for more battery stamina then turn off all off-screen gestures, ambient display and face unlock.battery performance will increase for sure.
    Ricanstyle likes this.
  12. @shaiksha Cupcake Dec 30, 2018
  13. O1528446305383 Cupcake Dec 30, 2018
    J1516699461291 likes this.
  14. Breezy10 Cupcake Dec 30, 2018
    Breezy10, Dec 30, 2018 :
    just updated via oxygen updater! worked like a charm! apparently the U.S is always the last to get these updates!
  15. hearty128b Eclair Dec 30, 2018
    i used a vpn to get the update
    Reanna Dookie likes this.
  16. G_Shakeer_Roxz_Gjau Eclair Dec 30, 2018
  17. vishrutkmr7 Gingerbread Dec 30, 2018
    vishrutkmr7, Dec 30, 2018 :
    IDK if it's a bug per sé but the Alert slider indicator is way too big after this update..
    GranP likes this.
  18. W1528365551906 Eclair Dec 30, 2018
    W1528365551906, Dec 30, 2018 :
    Received update in India. Download Secure VPN, select German VPN now connect it. Check in settings-system-system update. Download and install.
  19. ade0410 Honeycomb Dec 30, 2018
    ade0410, Dec 30, 2018 :
    are you taking the Mick?
    it's always been that size.
    you move the alert slider, it's shows the current setting then disappears after a few seconds.
    is it really that much of a problem?
    how often do you use it!
    get real.
  20. E1535734948228 Cupcake Dec 30, 2018
