598
OxygenOS 9.0.3 OTA for OnePlus 6
  1. Q1546079847738 Cupcake Dec 31, 2018
  2. jeevanbatla Froyo Dec 31, 2018
  3. Roger.T Jelly Bean Dec 31, 2018
  4. F_Sasy_Levy_wcTQ Cupcake Dec 31, 2018
    F_Sasy_Levy_wcTQ, Dec 31, 2018 :
    Hi. If i in beta version.
    The update can help to return to stock without to return to oreo and erase the device?
    Thanks
  5. Q1546079847738 Cupcake Dec 31, 2018
    Q1546079847738, Dec 31, 2018 :
    I have already update from Germany server . But this update have some extra thinks but Germany update not have..
    Is Germany update harm my software experience?
  6. drl431 KitKat Dec 31, 2018
    drl431, Dec 31, 2018 :
    Short answer is no.
    See instructions on beta page (where you obtained beta).
  7. Punith_Chandra Cupcake Dec 31, 2018
  8. Q1546079847738 Cupcake Dec 31, 2018
  9. drl431 KitKat Dec 31, 2018
    As previously discussed, the change log with the update is simply less detailed that the one on the first post.
    Q1546079847738 likes this.
  10. Q1546079847738 Cupcake Dec 31, 2018
    can you send me ta picture of your mbl update "channgelog"??
  11. drl431 KitKat Dec 31, 2018
    They are all the same. Just look a few pages back.
  12. N1543042638010 Cupcake Dec 31, 2018
    N1543042638010, Dec 31, 2018 :
    just install oxygen updater from play store and check update in oxygen updater for 9.0.3. you can install from there.
  13. meetamithkumar Cupcake Dec 31, 2018
    meetamithkumar, Dec 31, 2018 :
    Hello.. I haven't still received the update. Do something for dual camera in front side. other lens should be used for better image quality
  14. Miguel Quezada Jelly Bean Dec 31, 2018
  15. Ayappan Devendar Donut Dec 31, 2018
  16. Ruy_peixoto Eclair Dec 31, 2018
  17. F_Sasy_Levy_wcTQ Cupcake Dec 31, 2018
  18. Dvynshu Froyo Dec 31, 2018
    Dvynshu, Dec 31, 2018 :
    There is no dual camera for front[e]1f602[/e]
    meetamithkumar likes this.
  19. Drușcă Cupcake Dec 31, 2018
  20. Dodkrake Ice Cream Sandwich Dec 31, 2018
    Dodkrake, Dec 31, 2018 :
    Update not received in new Delhi India yes please when update release I'm desperrat battery life bad poor sir thank you sir release update pls.
