139
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. Slavomir Latka
    Eclair Jul 2, 2019
    Slavomir Latka , Jul 2, 2019 :
    @Manu J.
    Could you to do full 9.0.4 for us? I was got problem with overheating and want to be sure that I will have directly 9.0.4 instead of waiting with 9.0.3 in phone. I'm back on 5.0.8 till we will have new full upgrade.
    thank you very much
  2. michdeskunk
    Gingerbread Jul 2, 2019
    john.hem likes this.
  3. vivek1507
    Froyo Jul 2, 2019
    vivek1507 , Jul 2, 2019 :
    go your nearest service center he will replace cemera free of cost it's general issue
  4. Y1562074530548
    Cupcake Jul 2, 2019
    Y1562074530548 , Jul 2, 2019 :
    1. I tried few scenarios when I call my own OPT3 and the display shows normally.
    2. Tried it and works for me. (also never had this problem before)
    3.-
    4. Never had this problem. try to turn off Adaptive Battery.
  5. ghostofcain
    Marshmallow Jul 2, 2019
    ghostofcain , Jul 2, 2019 :
    It can't but if you want official OOS pie, you either have to bite the bullet and wipe, technically you don't even have to relock the bootloader or wait until OnePlus decide to address the issue.
    PTuT and Auristic like this.
  6. Blue-agila
    Ice Cream Sandwich Jul 2, 2019
    ghostofcain and Auristic like this.
  7. Blue-agila
    Blue-agila , Jul 2, 2019 :
    Not on beta by any chance?
    ghostofcain likes this.
  8. Karthik_Dasari
    Cupcake Jul 2, 2019
  9. ghostofcain
    Wouldn't make a shred of difference if they had, the roll out is non geographical.
    Auristic likes this.
  10. aakarpost
  11. PTuT
    Jelly Bean Jul 2, 2019
    PTuT , Jul 2, 2019 :
    The easiest would be if they just address the issue. But, they are silent like it didn't exists...that's silly and childish. And, if they can't find courage to acknowledge the problem then just silently fix it. Can't be that hard, or can it?
  12. AlCatpone
    Cupcake Jul 2, 2019
    AlCatpone , Jul 2, 2019 :
    Hi OP3T user here.
    I downloaded the update and now only the Recovery Booter starts.
    I cant install the update over the Recovery Booter nor the sideloader.
    I also cant get to my user files when connecting the phone to my pc.
    Some of the solutions here would require me to go into Dev mode, which i cant because i cant boot the firmware.
    Any Ideas? I just want to at least get my files back
  13. Fhdshahzad
    Fhdshahzad , Jul 2, 2019 :
    This is interesting, because unlocked bootloader device are experiencing issues with update.
    Are you sure it's unlocked?
    Well let's say if it's unlocked so why the others are getting issues while installing 9.0.4 on OP3. So if you have any bright ideas please enlighten us.
  14. Jain_Ronu
    Froyo Jul 2, 2019
    Jain_Ronu , Jul 2, 2019 :
    Connect with PC and push the full ROM zip file using Push command. Then u can install it using ur phone only.
  15. AlCatpone
    Cupcake Jul 2, 2019
    I cant connect to the phone over adb. And i dont know if i did something wrong or the phone is. Thanks for the idea tho
  16. Sadra_Imam
    Sadra_Imam , Jul 2, 2019 :
    I just updated to 9.0.4 from 9.0.3 and I can confirm the incoming calls wake up delay is fixed and I don't see this issue right now.
    The UI feels a little snappier but the animations are still there.
    no idea regarding battery right now, I didn't have battery issue on 9.0.3 and I will report back after few cycles.
    so far so good.
  17. Sadra_Imam
    by the way, I used oxygen updater app.
    Just one thing I want to ask, I don't see any change log in settings update page. can anyone confirm this.
  18. NIRJHOR007
    Eclair Jul 2, 2019
    NIRJHOR007 , Jul 2, 2019 :
    camera bug in manual mode.
    multiple app suddenly closed like chrome,facebook .
    pubg and asphalt 9 performance is good.
    very less heating icchus.
  19. Pratik1307
    Froyo Jul 2, 2019
    Pratik1307 , Jul 2, 2019 :
    vijayanaveen
    After update OOS 9.0.4 also unable to find ( SAR value) verification window in about section. also tried Dial code *#07# unable to find the same.​
    Check bro... I have it...
  20. Cervantes
    Moderator Moderator Jul 2, 2019
