139
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. Sridhar Ananthanarayanan
    Lollipop Jun 30, 2019
    Sridhar Ananthanarayanan , Jun 30, 2019 :
    It works just the way it would had they included in the rom.
    I just downloaded the digital wellbeing app from apkmirror and it works fine too. In case you don't see it in the app drawer, enable it under quick settings (by long press on the toggle) and make it visible in the app drawer.
  2. B.yashaswi
    Ice Cream Sandwich Jun 30, 2019
    B.yashaswi , Jun 30, 2019 :
    have you downloaded the digital wellbeing of Google LLC??
  3. Sridhar Ananthanarayanan
  4. Matthieu Vermeulen
    Froyo Jun 30, 2019
    Matthieu Vermeulen , Jun 30, 2019 :
    this is a thread about update 9.0 4. not 9.0 3....
    B.yashaswi likes this.
  5. pavanraghavaraju
    Gingerbread Jun 30, 2019
  6. dhamup
    Cupcake Jun 30, 2019
    dhamup , Jun 30, 2019 :
    Bluetooth connection has lot of background noise for all the calls and Bluetooth tethering reboots the phone.
    G_Pulkit_Kanoje_ZQpv likes this.
  7. Bintang12
    Honeycomb Jun 30, 2019
    Bintang12 , Jun 30, 2019 :
    SMH
    H. Erol, dcuatro and Varun Narayan like this.
  8. sthar13
    sthar13 , Jun 30, 2019 :
    nope. It is an issue on android Pie. Had no issue with Oreo
    amralomari likes this.
  9. 0llifreak
  10. PCesar.Cercal
    KitKat Jun 30, 2019
  11. Aditya Dange
    Aditya Dange , Jun 30, 2019 :
    Requested Zenmode for 3/3T.... Let's hope for the stable n snappy build this time with 9.0.4.
    G_sagar_jaware_osJK and Zeus13 like this.
  12. BeingIncog
    Nougat Jun 30, 2019
    Pradeep@1+ likes this.
  13. PARTHI_SaNjay
  14. abidbunny
    Honeycomb Jul 1, 2019
    abidbunny , Jul 1, 2019 :
    Screen recorder not working when i records screen sound not come in earphones.
    Digital wellbeing working fine for me i using this from 3 months. To access this app you have to add this app notification bar toggle the n open it from there and turn on the show icon.
  15. Praty_28
    KitKat Jul 1, 2019
    Praty_28 , Jul 1, 2019 :
    But is your /data partition encrypted? To check goto settings, >> security and lockscreen >> Encryption & credentials if it says phone not encrypted you can go ahead and flash without any data loss. But afaik there was some problem regarding decryption keys which caused corruption of data partition after updating if you had an encrypted /data partition and unlocked bootloader.
  16. iamlenix
    Donut Jul 1, 2019
  17. Bharanivijay
    Bharanivijay , Jul 1, 2019 :
    My phone was encrypted before updating. My internal storage is not wiped after updating 9.0.4.
  18. Bharanivijay
    #38
    Roman Ruslanoveth likes this.
  19. Praty_28
    KitKat Jul 1, 2019
    But was your bootloader unlocked? Did you flash using twrp?
    #39
  20. Bharanivijay
    Yes.
    #40
