119
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. G_goh_chenhwang_Likw Cupcake Jul 11, 2019
    G_goh_chenhwang_Likw, Jul 11, 2019 :
    I not sure is this update causing camera apps crash always... Need to restart the phone to recover... Any 1 having same issue after update?
  2. sourabhmaini Donut Jul 11, 2019
    sourabhmaini, Jul 11, 2019 :
    call app has become slow after this update.
    screen is black but the phone keeps on ringing.
    can you help me out from this problem.
    thanks
  3. Trevor.Hawkes Ice Cream Sandwich Jul 11, 2019
    Trevor.Hawkes, Jul 11, 2019 :
    Two and a half years isn't bad but even so you still expect OnePlus to help, even if they say the problem can't be fixed.
  4. Sridhar Ananthanarayanan Lollipop Jul 11, 2019
    Sridhar Ananthanarayanan, Jul 11, 2019 :
    Which recovery are you using? Use latest official TWRP.
  5. jeaneco Donut Jul 11, 2019
    jeaneco, Jul 11, 2019 :
    unfortunately, after having installed the new update there are major issues while the phone is set on airplane mode: it switches off by itself. Does anyone know what to do?
    S1524149544966 and Anand_Nair like this.
  6. Sridhar Ananthanarayanan Lollipop Jul 11, 2019
    Wind-down isn't working. It isn't required either because you can schedule both DND and night mode independently under settings (this is basically what wind-down does).
  7. THEHARDIK Froyo Jul 11, 2019
    THEHARDIK, Jul 11, 2019 :
    Turning off pocket mode might help. I suggest you to hard reset your phone once you update. It worked for me. ( I am not experiencing any kind of lags in new update )
  8. THEHARDIK Froyo Jul 11, 2019
    It is not rare. He might have done hard reset recently before or after the update. It helps. I suggest you to try that too. As fas as my device is concerned, It is running quite good. #NotAFanboy.
  9. RITESH KUMAR DAGA Donut Jul 11, 2019
    RITESH KUMAR DAGA, Jul 11, 2019 :
    THEHARDIK
    It is not rare. He might have done hard reset recently before or after the update. It helps. I suggest you to try that too. As fas as my device is concerned, It is running quite good. #NotAFanboy.​
    and for the reset I will have to take backup first right.
  10. ghostofcain Marshmallow Jul 11, 2019
    ghostofcain, Jul 11, 2019 :
    Only if you have unbackedup data you need to keep.
    Auristic likes this.
  11. Huey_Karteur Donut Jul 11, 2019
  12. sarodeab Cupcake Jul 11, 2019
    sarodeab, Jul 11, 2019 :
    Same here, my phone is too slow after latest update.
  13. ghostofcain Marshmallow Jul 11, 2019
    What other function where you expecting from a camera?
  14. Huey_Karteur Donut Jul 11, 2019
    Huey_Karteur, Jul 11, 2019 :
    Panorama and Slow mo that were there before
  15. ghostofcain Marshmallow Jul 11, 2019
    When you swipe up, are the advanced settings not present?
    Huey_Karteur likes this.
  16. Huey_Karteur Donut Jul 11, 2019
    Oups my bad I feel like oldies with new tech ...
  17. gurubs Cupcake Jul 11, 2019
    gurubs, Jul 11, 2019 :
    Just like few other users phone has become very slow after 9.0.4 update. Especially the calling app and putting on/off for speaker phone has gone extremely slow. Battery drain also seems like highly increased. Not faced this issue ever earlier.
  18. THEHARDIK Froyo Jul 11, 2019
    That's right.
    RITESH KUMAR DAGA likes this.
  19. RITESH KUMAR DAGA Donut Jul 11, 2019
    THEHARDIK likes this.
  20. A1562842247418 Cupcake Jul 11, 2019
    A1562842247418, Jul 11, 2019 :
    After latest Android update for Oneplus 3T, the phone is having many issues like:
    1. Phone lags so much even when just two apps are open.
    2. Front camera quality has decreased significantly.
    3. Adaptive brightness doesn't work.
    4. There is significant delay in disconnecting calls when we press End Call button. Also there is delay in action of all the touchscreen options while on call. It seems like phone is lagging even during simple phone calls, even when there is no app opened.
