119
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. jeaneco Donut Jul 11, 2019
    jeaneco, Jul 11, 2019 :
    plus it fully turns off when it is on airplane mode...
    Anand_Nair likes this.
  2. Zazenoz Donut Jul 11, 2019
    Zazenoz, Jul 11, 2019 :
    I try to turn on OTG and plug the USB stick, but it's not working, The notification don't appear.
    I've tried with a:
    - USB type C stick - SanDisk 64 gb fat32 format
    - USB A stick - Kingston 4gb fat32 format
    The same stick's working fine in my Galaxy S9
    Any ideas?
  3. wospino Honeycomb Jul 11, 2019
    wospino, Jul 11, 2019 :
    may be a hardware problem I'm using a SanDisk USB/OGT type C stick and it works, but yo can test it with the TWRP custome recovery.
  4. S1524149544966 Cupcake Jul 11, 2019
    S1524149544966, Jul 11, 2019 :
    same problem bro my op 3t
    jeaneco likes this.
  5. Leopoldvb Cupcake Jul 11, 2019
    Leopoldvb, Jul 11, 2019 :
    I am having insane lagspikes on my Oneplus 3 after installing the Pie update and with the security update from 2019.6 that you mention above it get even worse :( The phone lags even with one app open. Is there going to be a fix for these lag issues soon?
    jeaneco likes this.
  6. mohd_areeb Gingerbread Jul 11, 2019
    mohd_areeb, Jul 11, 2019 :
    Here is my battery usage!
    Is it normal or needs battery replacement?
    please provide your opinions
  7. zeetheali Gingerbread Jul 11, 2019
    zeetheali, Jul 11, 2019 :
    mobile network standy is using too much of battery. they need to fix this. they just want 3/3T users to upgrade their devices with new ones so they are doing apple thing with us.
    Seb79 likes this.
  8. hacii Donut Jul 11, 2019
    mohd_areeb likes this.
  9. mohd_areeb Gingerbread Jul 11, 2019
    yes, mine too, And sometimes it auto changes to normal charging, i had to re-plug, It again, to dash charge!
    hacii likes this.
  10. amit.exe786 Cupcake Jul 11, 2019
    amit.exe786, Jul 11, 2019 :
    when phone rings in pocket for incoming call, then if bring it out for receiving that call, it goes to lock screen mode and i need to use fingerprint or pin to receive the call. there is also a problem, the call screen goes backend , habe to attend call from notification bar.
    G_Dani_Galindo_Ruhd likes this.
  11. hacii Donut Jul 11, 2019
    hacii, Jul 11, 2019 :
    i have cleared cache already but no effect
  12. ghostofcain Marshmallow Jul 11, 2019
    ghostofcain, Jul 11, 2019 :
    But surely anyone but a moron, would take their money to another manufacturer? Or are you suggesting OnePlus users are so gullible that OnePlus can knacker the device with an update and still rely on repeat business.
    Auristic likes this.
  13. Ati24 Eclair Jul 11, 2019
    Ati24, Jul 11, 2019 :
    Pie frissítés: 1 év után ezt sikerült összehozni...Jó munkához idő kell... Inkább ki sem adták volna...
    Pie update: After 1 year we managed to bring it together ... Time to do good work ...  I wouldn't have given up ...
  14. iandreoli Cupcake Jul 11, 2019
    iandreoli, Jul 11, 2019 :
    Complete Disaster, phone just factory reseted and got toooooo slow with this update. I'm really disappointed
  15. abhibnl Ice Cream Sandwich Jul 11, 2019
    abhibnl, Jul 11, 2019 :
    The stock kernel and overall stock config is indeed laggy. I am using 9.0.4 with mcd kernel Pie builds and it's been a smooth experience so far. No bugs as per "my personal usage" and everything just works.
  16. G_Subrat_Nayak_eMEB Donut Jul 11, 2019
    pualai and mikica023 like this.
  17. G_Sadra_Imam_zxUt Gingerbread Jul 11, 2019
    G_Sadra_Imam_zxUt, Jul 11, 2019 :
    Pie needs more work and optimization. It's far away from the best OOS yet which is 5.0.8
    I hope OnePlus don't give up on "General bug fixes and improvement" for 3/3T.
    THEHARDIK, jeaneco and S1543657713145 like this.
  18. MapleEssence Cupcake Jul 11, 2019
    MapleEssence, Jul 11, 2019 :
    Yeah, I just went back to Oreo. This has way too many bugs for me to consider it usable. I'm a very mellow person and I've had no real complaints prior with any update on the OP1 or 3T (that couldn't be solved with a simple cache wipe or reset), but yeesh.
    I'll be getting a new phone next year and if this is just left to rot like this it likely won't be from Oneplus. This update should not be live.
  19. Brian OBrien Gingerbread Jul 11, 2019
    Brian OBrien, Jul 11, 2019 :
    It's not called "dash charge" anymore. Lockscreen says "charging rapidly". LED notification for "charging rapidly" is set to blue by default and I don't think it can be changed by user. I've set LED notification for normal speed "charging" to purple.
    I'm on 9.0.4 and battery charges from 5% to 100% in about 55 - 60 minutes. LED usually indicates blue immediately on plugging in. Very occasionally it indicates purple for 1 - 2 minutes before changing to blue.
    For me, battery usage is similar to Oreo and maybe a little better. I hope it stays that way. I switched off both Advanced Battery Opimisation options but left Adaptive Battery on and accepted its recommendations - restricted apps include applocker, Google Play Services, WhatsApp, Brave and Contacts. All's working well so far including WhatsApp notifications which I was concerned about.
    I leave phone switched on overnight and don't use Airport mode. Last night, battery drain from approx midnight to 08:15 was 2%.
    I've always updated official releases OTA, never unlocked bootloader and always cleared cache from recovery after updates. I've never factory reset. I don't do gaming. All is working perfectly for me with no lagging and just one problem:
    Sometimes, when I close Brave browser, the navigation bar does not appear on the home screen until I refresh it. It doesn't bother me.
  20. João Figueiredo Gingerbread Jul 11, 2019
