139
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. mohd_areeb
    Honeycomb Jul 16, 2019
  2. oneplus7vj
    Cupcake Jul 16, 2019
    oneplus7vj , Jul 16, 2019 :
    Hi Team,
    With the latest update , the call answering screen is not visible untill 8-10seconds when call comes. this is happening only with the latest update 9.
    0.4. even finger print control doesn't work some times.
  3. R1563256343585
    R1563256343585 , Jul 16, 2019 :
    如何安装
    太田升级?
    还是twrp安装?
    我用twrp安装
    但它会循环启动屏幕
    Translated:
    how to install
    Ota upgrade?
    Or twrp installation?
    I installed with twrp
    But it will cycle the boot screen
  4. mikica023
    mikica023 , Jul 16, 2019 :
    English ?
  5. mohd_areeb
    mohd_areeb , Jul 16, 2019 :
    转到设置,只需检查系统更新! 或者从Play商店下载Oxygen Updater应用程序并检查您的设备的可用更新!
    Translated:
    Go to settings and just check for system updates! Or download the Oxygen Updater app from the Play Store and check for available updates for your device!
  6. mohd_areeb
    我认为你陷入了bootloop,尝试从恢复中清除缓存,或者恢复出厂设置。 要安装twrp,您需要首先解锁引导加载程序然后闪烁twrp。
    Translated:
    I think you are stuck in the bootloop, trying to clear the cache from recovery, or to restore the factory settings. To install twrp, you need to first unlock the boot loader and then flash twrp.
  7. jack_the_beast
    jack_the_beast , Jul 16, 2019 :
    it did for me, basically the if you were in normal mode at media volume 5 (for example), when you swithced to silent the phone would put media at 0 but with a single touch of the volume keys it would go directly to 5 again.
    but i think the important thing was that vibrate and silent mode would actually mute media, while on Pie it doesn't happen. I even tried to do a cache wipe
  8. legaceemwangz
    legaceemwangz , Jul 16, 2019 :
    trying to root after oos 9.0 4 update, managed to unlock BL and install TWRP but stuck, super su not installing, tried to wipe dm no verity then wipe but best i get is ENCRYPTION FAILED msg then phone asks me to. factory reset. HELP, i am a power user who needs root
  9. G_Bora_Dhanuja_lGjN
    arash9 likes this.
  10. arash9
    Froyo Jul 16, 2019
    arash9 , Jul 16, 2019 :
    battery drainage problem
    the fingerprint doesn't work properly anymore
  11. G_Олег_Сербин_
    G_Олег_Сербин_ , Jul 16, 2019 :
    In this update, 9.0.4, the developers spoiled the work of video filming, namely stabilization, the video does not stabilize, but rather removes it so that it destabilizes. fix this bug in the next update. I can also add that the battery life has become less in time compared to 9.0.3.
  12. G_Aditya_G_evPB
    Froyo Jul 16, 2019
  13. arturjot
    Eclair Jul 16, 2019
    arturjot , Jul 16, 2019 :
    Yep, happens to me as well.
  14. P1555919653374
    Eclair Jul 16, 2019
    P1555919653374 , Jul 16, 2019 :
    after the update to 9.0.4 the camera quality has been lacked. camera is not focusing at all properly
  15. Denis Mukhin
    Denis Mukhin , Jul 16, 2019 :
    It' common hardware problem for this device that focusing stops working, it requires back camera module to be replaced:( Update could cause this issue to appear but real nature is hardware
  16. SMihai
  17. Denis Mukhin
    I suggest to use Magisk
  18. Denis Mukhin
  19. SMihai
    SMihai , Jul 16, 2019 :
    This is only stock camera. i don't have GCam mods.
  20. dcop7
    dcop7 , Jul 16, 2019 :
    Those options aren't available for stock camera for OP3/T. There isn't anything to fix.
