138
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. 0anas01
    Donut Jul 20, 2019
    0anas01 , Jul 20, 2019 :
    ok..thanks bro..will try it. if it doesn't work, can roll back to 5.0.8. so its worth a try. gotta take backup anyways
    THEHARDIK likes this.
  2. wospino
    Honeycomb Jul 20, 2019
    wospino , Jul 20, 2019 :
    waiting for my OnePlus 7 pro nebula (12gb of ram/256gb storage) to arrive ;)
    0anas01 likes this.
  3. H1558677068128
    Cupcake Jul 20, 2019
    H1558677068128 , Jul 20, 2019 :
    I'm using oxygen update so now what should I do for updating? is it incremental update or beta update
  4. fouadmordi
    Gingerbread Jul 20, 2019
    fouadmordi , Jul 20, 2019 :
    i rollback to nougat 7.1.1 lol man the battery is fantastic and the thing that surprise me is that ram management is insane i open a game pubg mobile and facebook, messenger, playstore, youtube, and two other app and guess what ? i let them 15 minutes and they are still there when i was on oreo and pie if i open a game and i open another app the game reload lol what ? android nougat dont have optimisation app that's why not like pie and oreo but still without optimisation the battery in nougat is batter than oreo and pie and good performance.
    oneplususer23 and capriady78 like this.
  5. Dhananjayve
    Dhananjayve , Jul 20, 2019 :
    we still have low sound problem during calling. when this problem resolved? I have tried factory reset. any help appreciated
  6. Aabhijai
    Aabhijai , Jul 20, 2019 :
    Was having problems with the latest build with apps lagging and tried a custom ROM after unlocking the bootloader and with twrp. I didn't like the particular ROM and thought will try a clean install of 9.0.4. Installed it through TWRP and all good. Tried to relock bootloader using fastboot oem lock so can use Google pay. It gives the option YES/ NO . Obviously selecting YES is not helping and the bootloader still remains unlocked. Is it a known issue after Pie upgrade Or I am missing a step to lock the bootloader again
  7. angelantonio92
  8. ryan806
  9. Fadihadad
    Eclair Jul 20, 2019
    Fadihadad , Jul 20, 2019 :
    I had some problems like heating and battery drain and laggy installation of apps after 9.0.4! I thought to roll back to Oreo, but I gave a chance to reset settings and after that op3t worked probably good, fast and longer battery life than before resetting.
    take a back up, reset telefone, charge fully about 2 times, it will work good. that's my experience.
  10. arbeloa
    Cupcake Jul 21, 2019
  11. 0anas01
    Donut Jul 21, 2019
  12. S1509801375025
    Gingerbread Jul 21, 2019
  13. oneplususer23
    Eclair Jul 21, 2019
    oneplususer23 , Jul 21, 2019 :
    Yes, same here. I am experiencing general slowness in my OP3 too. I guess OP team did not test the update thoroughly. How can I fix this issue?
  14. oneplususer23
    Eclair Jul 21, 2019
    I am not experiencing this problem. It's your phone I guess.
  15. arbeloa
  16. AanandRoy
    Froyo Jul 21, 2019
    AanandRoy , Jul 21, 2019 :
    which oxygen os version, can you share that file???
  17. fouadmordi
  18. Kishan hadiyal
    Donut Jul 21, 2019
    Kishan hadiyal , Jul 21, 2019 :
    after this latest update I have issue with earpiece problem to much slow voice coming from ear speaker and also problem with my Samsung Level U too. Before update my bluthooth headset working fine. I can't volume up down from headset.
    Dhananjayve likes this.
  19. Yudhveersharma
  20. Akshay_Parmar_3502
    Donut Jul 21, 2019
