138
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. fouadmordi Gingerbread Jul 21, 2019
    fouadmordi, Jul 21, 2019 :
    lol they are slowing it so that you will buy a new phone just rollback to oreo or nougat like me i have no more headache...
    Kalyan, Seb79 and tushar.mokal like this.
  2. Akshay_Parmar_3502 Donut Jul 21, 2019
    Akshay_Parmar_3502, Jul 21, 2019 :
    Yes....
  3. Varyan Froyo Jul 21, 2019
    Varyan, Jul 21, 2019 :
    Turn on the Developers mode & change all 3 animations to 0.5x from 1x & see the difference.
    H1549090448354 likes this.
  4. Varyan Froyo Jul 21, 2019
    I am still on Android Pie 9.0.2 and it's running smooth without any issue. I think problem is with later updates like 9.0.4
  5. fouadmordi Gingerbread Jul 21, 2019
    yeah i agree it runs very smooth and the ui to but the battery and performance has a little bit drop besides that everything is smooth
    Varyan likes this.
  6. Blue-agila Ice Cream Sandwich Jul 21, 2019
    Blue-agila, Jul 21, 2019 :
    Is anybody else having problems with WoWiFi since the update 9.0.4
    Have had to role back to 9.0.3 and now works fine again
  7. fouadmordi Gingerbread Jul 21, 2019
    so in your opinion 9.0.3 is the stable ?
  8. Blue-agila Ice Cream Sandwich Jul 21, 2019
    No VoWiFi works on 9.0.3 but doesn't on 9.0.4.
    Didn't say anything about stability?
  9. fouadmordi Gingerbread Jul 21, 2019
    my brother have the 3t and updated it to pie 9.0.4 first it was slow but then with time it became a little faster i personally like pie because of it's smoothness with app opening and going to ram management everything is smooth, now im on 4.5.1 nougat i rollback yesterday and i did not experience any heat up or battery drop it became alot faster, my opinion if you want to buy a new phone just downgrade in nougat 4.5.1 before you buy one.
    U1555865613289 likes this.
  10. L1558542450041 Cupcake Jul 22, 2019
    L1558542450041, Jul 22, 2019 :
    how to downgrade brother. and how is the screen on time
  11. H1549090448354 Cupcake Jul 22, 2019
    H1549090448354, Jul 22, 2019 :
    right thanks i chenge my animation mobil is so fast.
  12. Z1560607584119 Cupcake Jul 22, 2019
    Z1560607584119, Jul 22, 2019 :
    Any higher version of oos of nougat for 3T?
  13. bandzula Cupcake Jul 22, 2019
  14. X1563778250109 Cupcake Jul 22, 2019
  15. X1563778250109 Cupcake Jul 22, 2019
  16. frazzaglia Donut Jul 22, 2019
    frazzaglia, Jul 22, 2019 :
    Hi all, I'm using pie 9.0.4 since one month and I've tried all settings (switch off adaptive battery, disable health service) and the phone is very bad. Battery draining, heating problem even if all it's very smooth.
    Will there be 9.0.5 in next months?
    Please fix these problems because I don't want downgrade to nougat/oreo or change phone (for instance with a Xiaomi mi a3 that it's a very good android one phone).
    Thanks ;)
    AndyRadikal likes this.
  17. BeingIncog Marshmallow Jul 22, 2019
  18. Denis Mukhin Cupcake Jul 22, 2019
    Denis Mukhin, Jul 22, 2019 :
    It may reduce issues but not eliminate them. For what I saw AOD and SystemUI restarting due to unability to respond on user input sometimes when resuming phone thus black screen delay appears. And it maybe related to power management and video driver. I suggest to disable AOD too but lags in interface still could happen
  19. Rosentine Donut Jul 22, 2019
    Rosentine, Jul 22, 2019 :
    Denis Mukhin
    It may reduce issues but not eliminate them. For what I saw AOD and SystemUI restarting due to unability to respond on user input sometimes when resuming phone thus black screen delay appears. And it maybe related to power management and video driver. I suggest to disable AOD too but lags in interface still could happen​
    haven't got any of this after turning off adaptive battery. Maybe you didn't make clean install? This is my way how I did this:
    TWRP installation -> Format all -> Install 5.0.8 from op support site -> install oxygen recovery -> boot system -> skip startup config -> upgrade to 9.0.4 -> turn off adaptive battery -> reboot -> recovery backup from Google accounts
    for last week I haven't experienced any issues, lags ect. works like Oreo.
    Denis Mukhin likes this.
  20. mohd_areeb Gingerbread Jul 22, 2019
    mohd_areeb, Jul 22, 2019 :
    I'm getting this SOT. It's actually very good though running on Android Oreo 5.0.8
    Since i rolled back from pie a few weeks ago or less!
    Everything got settled down having expected performance in PUBG Mobile as it should be!
    Overall no lags, no battery drain, no hangs etc.
    If you're facing problems too on pie, recommend you to rollback to oreo, some people rolling back to nougat it's not good though as oreo has dual gpu renderers and many more +ve points.
    AndyRadikal and arym like this.
