138
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. Cervantes
    Lollipop Moderator Jul 23, 2019
    Cervantes , Jul 23, 2019 :
    Hi
    The update thread is a thread of questions and/or commentary
    Please You read the first post
    Thread merged
  2. MGreyWolf
    Ice Cream Sandwich Jul 23, 2019
    MGreyWolf , Jul 23, 2019 :
    Best way to update is to clear the cache first then update using recovery. Just on the first charge cycle so far so good. No lag or whatsoever .
    Kalyan likes this.
  3. aarushrajani
    Froyo Jul 24, 2019
    aarushrajani , Jul 24, 2019 :
    just cache and then installed the software from internal storage
  4. F_Prashant_Karmacharya_U
    Honeycomb Jul 24, 2019
    F_Prashant_Karmacharya_U , Jul 24, 2019 :
    yeah did the same, feels snappy than before. [e]1f44c[/e][e]1f44c[/e]
    aarushrajani likes this.
  5. brmbjn
    Froyo Jul 24, 2019
  6. F_Rebecca_Ellis_SDPz
    Cupcake Jul 24, 2019
    F_Rebecca_Ellis_SDPz , Jul 24, 2019 :
    Since the update I've lost the WiFi calling. Although the option is selected it doesn't show on the top toolbar and doesn't work.
    Blue-agila likes this.
  7. L1547227815193
    L1547227815193 , Jul 24, 2019 :
    My keyboard collapse and i can't type anything for a few seconds!! this issue is random from Oreo to 9.0.4 any solution for my 3T please?
    Thx
  8. G_Алексей_Зайцев_INxl , Jul 24, 2019 :
    [QUOTE = "G_Алексей_Зайцев_INxl, сообщение: 20582154, участник: 2141572"] [QUOTE = "fouadmordi, сообщение: 20582034, участник: 1524191"] [ATTACH = full] 1079576 [/ ATTACH] [/ QUOTE]
    Где вы нашли этот предмет? [/ QUOTE]
    where is indicated how much RAM is consumed
  9. Z1560607584119
  10. Z1560607584119
  11. amit.exe786
    amit.exe786 , Jul 24, 2019 :
    after this kind of battery draining, should I go for battery replacement , or to wait for next update...
  12. Topper_Gas
    Jelly Bean Jul 24, 2019
    Topper_Gas , Jul 24, 2019 :
    Assuming you didn't have any major battery issues prior to the update replacing your battery won't fix any drain issues.
  13. amit.exe786
    but.... according to accu battery app my battery capacity is now 2400mah
  14. nabsrai
    Gingerbread Jul 24, 2019
    nabsrai , Jul 24, 2019 :
    My phone's battery drained out completely at night so I plugged in my phone for charging overnight in switched off state. In morning, I tried to turn on my phone while still being connected to the charger, the phone turned on but it showed a different lock screen ".... To start Android, enter password....". To my surprise neither my fingerprint nor my phone password worked. After few failed attempts I decided to restart my device by long pressing power button, and then regular lock screen...
    Anybody having some idea why that happened?
    (OnePlus 3T, OOS 9.0.4)
  15. AlcaloideDoErgot
    Eclair Jul 24, 2019
    AlcaloideDoErgot , Jul 24, 2019 :
    Hello there.
    Noobie question here. Looking for my answer, but still could not find it: I am running on Android 7.1.1 (oxygenOS 4.5.1) and on system update it says oxygenOS 5.0.6... Should I do it first or is it possible to download the lastest 9.0.4 to my phone and update from there? Thanks and sorry if this has already been answered.
  16. Blue-agila
    Ice Cream Sandwich Jul 24, 2019
    Blue-agila , Jul 24, 2019 :
    Same here. I have submitted a bug report but no reply yet
  17. Prattech
    Prattech , Jul 24, 2019 :
    You will need to download 5.0.6 first and install to oreo. Then the pie update will show up. If you want to directly go to pie then you need to clean install 9.0.* from recovery or local update option in setting by downloading the file to root folder.
  18. Kishan hadiyal
    Donut Jul 24, 2019
    Kishan hadiyal , Jul 24, 2019 :
    yes call recording feature is available in 9.0.4
  19. Z1560607584119
    Cupcake Jul 25, 2019
    Z1560607584119 , Jul 25, 2019 :
    Will it wipe data?(If I install direct Pie from recovery?)
    P1544699139753 likes this.
  20. Z1560607584119
    Kishan hadiyal likes this.
