139
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. Mostafa Galib
    Cupcake Jul 26, 2019
  2. G_S_Mohsen_Houshyar_FgPB
    Froyo Jul 26, 2019
  3. Pradeep@1+
    Ice Cream Sandwich Jul 26, 2019
    Pradeep@1+ , Jul 26, 2019 :
    OP already promised bimonthly security patch updates so maybe July patch by August [e]1f60a[/e][e]1f60a[/e]
  4. Z1564130433773
    Z1564130433773 , Jul 26, 2019 :
    Hello Team,
    I am Oneplus 3T user. i had been updated my phone in android 9 around 1 month back.
    now i am getting 3 issues immediately after updated in android 9.
    1. Phone hang problem start. which i have never face since 2.5 years
    2. Internal call recording now stucked, shows exclaimed symbol (!) while calling on recording icon.
    3. after disconnect the call, calling sign shown at the top and calling screen shown with out caller id or any other information except call end button.
    please refer the below screenshot for same.
    Kindly resolve this issue or guide me to how to downgrade in android 8.
    Thanks,
    aMir aHmed
  5. frazzaglia
    Donut Jul 26, 2019
  6. Z1564130433773
  7. L1547227815193
    L1547227815193 , Jul 26, 2019 :
    Please fix latency of keyboard i have problems to write fast and this issue is random. Im not the only one...
    Thx
  8. frazzaglia
    Donut Jul 26, 2019
    TR.Engin.Akbulut likes this.
  9. K1547120206649
  10. Kishan hadiyal
    Donut Jul 26, 2019
    Kishan hadiyal , Jul 26, 2019 :
    I don't know more abt it. I have this call recorder app
    frazzaglia likes this.
  11. dcop7
    Honeycomb Jul 26, 2019
    dcop7 , Jul 26, 2019 :
    You aren't the only one? I didn't saw another report like that. Did you try other keyboards? Did you factory reset the device? What steps did you do?
    Some countries is illegal to record calls. Depending on your country, that option could not be available.
    What are your usage? If you are gaming hard, 1% per minute doesn't seems like that is a battery drain. You need to post details, as much as you can. What is your OOS version? What are your stats? 1% is when the phone is sleeping? Do you have wifi, bluetooth, nfc, etc on? Etc etc etc... This is just an examples that you should always indicate when posting an issue. How can anyone help if you don't provide details?
  12. BuenoAmigo
    Gingerbread Jul 26, 2019
    BuenoAmigo , Jul 26, 2019 :
    These are things people don't report and even if reported it's ignored. Several of these things reported as bug lies there just like a mummified remain. Nobody cares. One set of useless people just say factory reset even if they are told it's done. Still not fixed means, they blame the user. And these guys are from oneplus and keeps bothering others like they have no other work. I just come to forums to see if there are any fixes mentioned, but rarest of the rare it happens.
    No use complaining to OnePlus anymore. Better to buy pixel! Double the price and faster fixes. OnePlus also went corrupt now. Greedy pushing bad updates and getting next version of the OnePlus out. Slowing down phones will make people buy new ones. In OnePlus case, after 3 and 5 series, the quality is not good to last even months. Glass back for frequent new phones!! Because it cracks easily.
    Contin Maurizio_IT and nabsrai like this.
  13. L1547227815193
    All steps: factory reset, Oreo, 9.0.1+2+3+4, clean caché and same results, latency and collapse with gboard or swiftkey or similar keyboards.
    Its and old problem (try to search on google)
    I know several cases in my country (local forum)
    Thx
  14. K1547120206649
  15. F_Prashant_Karmacharya_U
  16. Topper_Gas
    Jelly Bean Jul 26, 2019
    Topper_Gas , Jul 26, 2019 :
    With an attitude like yours then good luck finding somebody who is prepared to take their time to trying and assist you. Most users seem to be finding a solution if they take their time looking for one.
  17. drblamith
    drblamith , Jul 26, 2019 :
    After the 9.0. 3 and 9.0.4 updates, system has become very slow.. Incoming call display lag by atleast 10 sec after ringtone. Opening of all the apps atmre delayed by atleast 3 seconds.. Not the kind of one plus 3 phone when I had bought..
  18. drblamith
    Same issue mine as well..
  19. MichaelMerkel
    MichaelMerkel , Jul 26, 2019 :
    yes. same here.
    and that means at least:
    - Google pay is not working
    - Netflix can not even be installed!
    unfortunately no answer yet from OnePlus.
    regards
    Michael
  20. Tanshid_45
    Eclair Jul 26, 2019
    Tanshid_45 , Jul 26, 2019 :
    after this update I cannot use hotspot on my phone...if I have to use it I gotta restart as well as no screen mirroring :/ ....please fix this issue
