138
OxygenOS 9.0.4 for OnePlus 3 & OnePlus 3T
  1. P1554275367570 Eclair Aug 7, 2019
    P1554275367570, Aug 7, 2019 :
    B1559666266408 likes this.
  2. nabsrai Gingerbread Aug 7, 2019
    nabsrai, Aug 7, 2019 :
    And every update is so poorly written and implemented that it compulsorily needs a factory reset. So, your advice is good and valid and it proves that there's fault in coding rather than user's usage.
    oneplususer23 likes this.
  3. G_sumit_azad_sMQC Eclair Aug 7, 2019
    G_sumit_azad_sMQC, Aug 7, 2019 :
    After a long use with OxygenOS 9.0.4 the issues i am facing is that when someone calling the screen will remain black for 15-20 sec. most of time call get disconnected and screen remain black you have to wake up the screen by using power button to take call
    2nd issue that i faced is that sometime screen get freezed when you scroll down your screen either on youtube or other app which have longer pages no other problems is noticed till now.
  4. rarog Lollipop Senior Moderator Aug 7, 2019
    rarog, Aug 7, 2019 :
    Looks like a rollout of 9.0.5 is about to start. If your problems persist even after update, you should open a bug report.
  5. oneplususer23 Eclair Aug 7, 2019
    oneplususer23, Aug 7, 2019 :
    Well I don't think the problems will go away. I am buying one plus 7. it's been 3 years so it's time to change my phone. OnePlus will deliberately slow down OnePlus 3 now. it's a strategy being followed by all phone manufacturers nowadays and which is unfair.
    N1565360981588 likes this.
  6. H1549090448354 Cupcake Aug 7, 2019
  7. Z1560607584119 Cupcake Aug 7, 2019
  8. H1549090448354 Cupcake Aug 7, 2019
    H1549090448354, Aug 7, 2019 :
    no not any old type of problems
  9. H1549090448354 Cupcake Aug 7, 2019
    Thanks God.too much bugs r fix in this update.
  10. Z1560607584119 Cupcake Aug 7, 2019
    Z1560607584119, Aug 7, 2019 :
    Overwhelmed to listen a positive comment for oos![e]1f602[/e]
  11. Abhi Dahiya Ice Cream Sandwich Aug 7, 2019
    Abhi Dahiya, Aug 7, 2019 :
    What bugs do you feel or see as fixed in this new update?
  12. Auristicpleaseignoreme Froyo Aug 7, 2019
  13. ghostofcain Marshmallow Aug 8, 2019
    ghostofcain, Aug 8, 2019 :
    Yet by giving them more money you are showing your support for this perceived behaviour. If I suspected an OEM was behaving this way they'd never get another penny off of me.
    rarog likes this.
  14. oneplususer23 Eclair Aug 8, 2019
    oneplususer23, Aug 8, 2019 :
    well I am only suspecting this behavior and do not have proof. Hence, I will not act merely on suspicion. Also, most of the OEMs like Apple , Samsung, Xiaomi have adopted this strategy barring a few. There could be a virus in my phone which is slowing it down.
  15. Praty_28 Jelly Bean Aug 8, 2019
    Praty_28, Aug 8, 2019 :
    Well, he believes every manufacturer does this so which phone should he upgrade to? :rolleyes:
  16. G_S_Mohsen_Houshyar_FgPB Froyo Aug 8, 2019
    ghostofcain likes this.
  17. Praty_28 Jelly Bean Aug 8, 2019
    There could be some apps that could be slowing your phone down but virus on android phones is rarely a case unless you've downloaded shady applications from the web.
  18. G_sumit_azad_sMQC Eclair Aug 8, 2019
    rarog likes this.
  19. ghostofcain Marshmallow Aug 8, 2019
    Apple where sued for slowing down iPhones and the EU, told them they'd take a dim view if they did it again. You might think your OEM is slowing down your old phone but they'd be opening a whole can of worms, in the EU at least if they did.
  20. oneplususer23 Eclair Aug 8, 2019
    well there was only one called TubeMate to download YouTube songs. But I deleted it and the result is the same.
