231
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. Chiran_OP5
    Honeycomb Mar 1, 2019
    Chiran_OP5 , Mar 1, 2019 :
    I always jump from beta to stable and stable to beta and what I experienced that, only when I jumped from beta to stable then only the things are deleted.
  2. Aziz_Amin_Oneplus
    Jelly Bean Mar 1, 2019
    Aziz_Amin_Oneplus , Mar 1, 2019 :
    Obviously if you are shifting from Beta to Stable then things will get deleted, now every kid in Oneplus Community should know this up till now.
    ichinisan likes this.
  3. Chiran_OP5
    Yes I knew this only cause deletion of the data but as you said stable to stable update will also delete this , that's I can't understand.
  4. dipayans24
    Froyo Mar 1, 2019
    dipayans24 , Mar 1, 2019 :
    Bogo268
    try to clear cache from the app or do factory reset. in early days this was mai solution to similar problem​
    I did the clear cache process but it was still not working. Then I deleted the storage data of the 'phone' app which made the dialer working again, but now it does not switches with theme color i.e the dialer remains white even if I change theme to dark or colourful.
    Atleast I can make outgoing calls now.
  5. Q1545504703112
    Gingerbread Mar 1, 2019
    Q1545504703112 , Mar 1, 2019 :
    After upgrading to 9.0.4 the lag and stutter issue has been slightly improved but it does still exist
    Major Rager and anandsiddharth like this.
  6. Aziz_Amin_Oneplus
    Simple on Oxygen Updater if you are updating stable to stable you will not get your data or apps deleted and on local Upgrade you are updating from stable to stable then you will get your apps deleted but not your data now you understand.
  7. Chiran_OP5
    I performed local upgrade and as well as i performed from recovery as well. both the ways i never faced any issues as you've mentioned.
  8. Aziz_Amin_Oneplus
    My Apps gets deleted through local Upgrade that i can only say do not know from your side why it doesn't.
  9. Chiran_OP5
    I am also surprised knowing the issues you're facing.
  10. Aziz_Amin_Oneplus
    I will see through it later on while I see some magic is created on Beta thread so have to check it out.
  11. Bogo268
    Bogo268 , Mar 1, 2019 :
    Factory reset is you're last solution. Try it.
  12. sechinov
    Ice Cream Sandwich Mar 1, 2019
    mind_never likes this.
  13. Bogo268
    exactly
  14. dipayans24
    Froyo Mar 1, 2019
    Nope it takes a hell lot of time to setup from scratch. I can make calls atleast, so thanks for the concern.
  15. Bogo268
    you're welcome
  16. Swapspirate
    Froyo Mar 1, 2019
  17. P1512569276852
  18. sajjadmirza777
    Cupcake Mar 1, 2019
  19. mind_never
    Froyo Mar 1, 2019
    mind_never , Mar 1, 2019 :
    Sounds about right. Another rushed bugger. That happens with being short on manpower and added workload for new devices, which equals greed
    NickNap89, ichinisan and Paul_W_ like this.
  20. Speedlover777
    Speedlover777 , Mar 1, 2019 :
    Interesting insight. Thanks.
