231
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. kirospiro Froyo Mar 1, 2019
    kirospiro, Mar 1, 2019 :
    OnePlus 7 is coming out soon
  2. ricktendo Cupcake Mar 1, 2019
  3. PokiX Jelly Bean Mar 1, 2019
    PokiX, Mar 1, 2019 :
    Yes indirectly because when the system boot there is a function to overwrite the recovery with the one included in the zip file.
    ricktendo likes this.
  4. ricktendo Cupcake Mar 1, 2019
    ricktendo, Mar 1, 2019 :
    PokiX
    Yes indirectly because when the system boot there is a function to overwrite the recovery with the one included in the zip file.​
    Thanks, do you know the file name of the Recovery in the zip update?
  5. PokiX Jelly Bean Mar 1, 2019
    I haven't got a zip to check but that should be a file in the system.new filesystem. Twrp will rename or remove that file (if it can) to not get overwritten.
    You could look in Twrp source code or wait for someone knowing.
  6. Arvind9118 Froyo Mar 1, 2019
    StAr-NiC likes this.
  7. slmnanwr Froyo Mar 1, 2019
    slmnanwr, Mar 1, 2019 :
    The effort behind it and the bugs are understandable but I firmly believe that caller identification and bluetooth audio tuner have been in beta for way too long. 5 and 5T are both capable devices. #fam
    andreoski likes this.
  8. andreoski Froyo Mar 1, 2019
    andreoski, Mar 1, 2019 :
    audio tuner is not in beta for op5/t
  9. PokiX Jelly Bean Mar 1, 2019
  10. shivampatel1997 Froyo Mar 1, 2019
  11. markgangte96 Froyo Mar 1, 2019
  12. Arnab_1997 Eclair Mar 1, 2019
    Arnab_1997, Mar 1, 2019 :
    How is the performance as compared to 9.0.3? Did they address the lag issue? Also is the auto brightness fixed?
    dareknowak likes this.
  13. omarmawal Gingerbread Mar 2, 2019
  14. Harshm1992 Eclair Mar 2, 2019
    Harshm1992, Mar 2, 2019 :
    Bro I tried everything but no formula is working actually this is the bug in update. I am facing this issue first time till from the date when I purchased this phone.
  15. ThieRy64 Eclair Mar 2, 2019
  16. G_Arun_kumar_APdT Donut Mar 2, 2019
    Imrohit786 likes this.
  17. dashingfahad11 Gingerbread Mar 2, 2019
    dashingfahad11, Mar 2, 2019 :
    I'm facing problems with back button. This issue exists from long time like after the first pie update. Back button stops functioning sometimes where I have manually close all the apps or sometimes lock and unlock the screen to make it work again.. Any help would be appreciated.
  18. Apin Iroth Honeycomb Mar 2, 2019
  19. RockRakesh Cupcake Mar 2, 2019
    RockRakesh, Mar 2, 2019 :
    after update i found some headphone problems continuously connect and disconnect
  20. 12032016 Donut Mar 2, 2019
