232
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. NahbiCris
    Jelly Bean Mar 2, 2019
    NahbiCris , Mar 2, 2019 :
    No they are right when you deployed a new software version you have to do it incrementally, because you will test how it is performing and if they found a problem like the past beta they stop deploying it, also you saw this effect with the 9.0.0,9.01 and 9.0.2 where the one was stopped it and a few days later they launched a hot fix.
    This is known as Acceptance Testing in software development.
  2. Wrawoot12
    Eclair Mar 2, 2019
    Wrawoot12 , Mar 2, 2019 :
    Bro wait for it my device get this update today you should check for update in setting everyday!!
  3. NahbiCris
    it is open source so this is how you can trust them, because you and everyone can audit the code and see what it does.
    if you want to see it here is the code: https://github.com/arjanvlek/oxygen-updater
    Qwert Luiop and ANDREA F. like this.
  4. Rohan.M
    Gingerbread Mar 2, 2019
    Rohan.M , Mar 2, 2019 :
    Finally shutter sound bug is fixed in 9.0.4, where are those idiots who were shouting from roof tops that this is deu to Indian law, lol [e]1f602[/e] [e]1f61c[/e]
    rasulkhan7 likes this.
  5. Siddharth Jadav
    Eclair Mar 2, 2019
    Siddharth Jadav , Mar 2, 2019 :
    For all who is facing dialer FC bug, I've found a workaround and it works just fine. Follow the following steps and you'll be good to go.
    1. Download the OnePlus Phone apk from https://www.apkmirror.com/apk/onepl...ase/oneplus-phone-4-1-0-android-apk-download/
    2. Install the apk and open it. It'll crash but don't worry.
    3. Again go to Phone's app info. Tap on three dots on top right corner. Click on uninstall updates and then click on OK.
    4. Open the phone app again. DON'T CLICK ON DIALER BUTTON TO OPEN IT. EXIT THE APP IMMEDIATELY AFTER OPENING IT.
    5. Again go to Phone's app info and force stop it.
    6. Now open the dialer and you'll be good to go.
    Tested on OOS 9.0.4 OnePlus 5T.
    Hope this helps. [e]270c[/e]️
  6. Mahajanishaan
    Donut Mar 2, 2019
    G_BHARAT_JOSHI_Luru likes this.
  7. Mahajanishaan
    Donut Mar 2, 2019
    Mahajanishaan , Mar 2, 2019 :
    can I explain 4th step again, could not understand it
  8. Siddharth Jadav
    Eclair Mar 2, 2019
    Just open the app and exit it. Do nothing apart from opening the app.
  9. Mahajanishaan
    Donut Mar 2, 2019
    you also had same problem with frequent dailer contacts right,now it's solved?
  10. Abdelaziz Aqel
  11. patilpr
    Eclair Mar 2, 2019
    patilpr , Mar 2, 2019 :
    I found bug in this update after updating my OnePlus 5t to oxygen OS 9.0.4 I am unable to use my dial pad to dial any number. The error is coming "phone keep stopping".
    The 'phone' app is getting crash when we try to use dail
    pad.
    sechinov likes this.
  12. Bertsel
    Cupcake Mar 2, 2019
    Bertsel , Mar 2, 2019 :
    After download the Update, me 5T will not longer work. Display is not responding. Same in recovery mode and after restart.
    Any Idea?
  13. G_one_one
    Cupcake Mar 2, 2019
    G_one_one , Mar 2, 2019 :
    Problem with Google Assistant.
    When phone is unlock, "hey Google" "ok Google" doesn't work
  14. proharsh1
  15. rasulkhan7
    Froyo Mar 2, 2019
    rasulkhan7 , Mar 2, 2019 :
    What's The Latest Version of Camera for OnePlus 5T ?
    1551540260580.jpg Someone plz send me the link apk of the OnePlus 5t camera ! the pics are really worse after update , everything looks artificial ,it's not like a pic of 38k worth mobile
  16. drsalekin
    Donut Mar 2, 2019
    drsalekin , Mar 2, 2019 :
    wow, thanks for the help. it works. you are awesome...
    Siddharth Jadav likes this.
  17. Siddharth Jadav
    Eclair Mar 2, 2019
    No problem man. Just share the word.[e]270c[/e]️
    drsalekin likes this.
  18. Charmacas
    Charmacas , Mar 2, 2019 :
    After the update my version is 3.0.15. It seems like you've installed another version.
  19. rasulkhan7
    Froyo Mar 2, 2019
    can you plz send me the apk of yours ! please
  20. W1516013327393
    Eclair Mar 2, 2019
    W1516013327393 , Mar 2, 2019 :
    how is your experience? I'm on Oreo .just wanted to ask ?
