232
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. Aziz_Amin_Oneplus
    Jelly Bean Mar 7, 2019
    Aziz_Amin_Oneplus , Mar 7, 2019 :
    Q1545504703112
    I still had the lag issue on ob27​
    Oh then try for a clean installation, as I did a factory reset without erasing internal storage and then updated from recovery and everything is smooth and no lagging issues found on apps and scrolling too. And if you find otherwise then close the apps, clear cache for each app, restart and you are done.
  2. ErynOP
    Gingerbread Mar 7, 2019
    ErynOP , Mar 7, 2019 :
    Finally i upgraded yesterday to 9.0.4 (flash with twrp)
    I don't need anymore the developer option for the lags because now they mostly disapeared.
    Battery life is also good currently with 2h30 and 68% .
    danycmoi likes this.
  3. PokiX
    PokiX , Mar 7, 2019 :
    Don't forget that, apps including Google ones get updated, Google servers sometimes get reconfigured so unless you run a custom rom without Google apps, it's not that easy to state that one OS version has worse battery than another one.
    I force stopped GooglePlay, cleared its cache and datas and it seems to be a bit better. Try it.
  4. Aziz_Amin_Oneplus
    How can you stop Google Play Services, it doesn't have that option it's turned black when I click on it.
  5. W1548916655892
    Cupcake Mar 7, 2019
    W1548916655892 , Mar 7, 2019 :
    Still didn't add pie feature copy text from one recent apps to another apps in OnePlus 5. Android pie
  6. raveno123
    Ice Cream Sandwich Mar 7, 2019
    raveno123 , Mar 7, 2019 :
    Charge until the phone says it's full, turn charger off, turn phone off, then turn charger back on while the phone is still turned off, turn back on only when the phone says it's full again [e]1f44d[/e]
  7. raveno123
    what version are you on now?
    hoanbt likes this.
  8. bruno.l.j
    Cupcake Mar 7, 2019
    bruno.l.j , Mar 7, 2019 :
    Unfortunately the lag/frame rate drop appeared in 9.x.x is still here in 9.0.4.
    Please fix this as soon as possible. factory reset didn't solved it.
    Kaizen10, nikhilgarg.98 and Romanelo like this.
  9. hoanbt
    Cupcake Mar 7, 2019
    hoanbt , Mar 7, 2019 :
    Thank you, I downloaded it.
  10. Q1518162216468
    Donut Mar 7, 2019
  11. just_an_R
    Donut Mar 8, 2019
  12. dedeturtle
    Donut Mar 8, 2019
    dedeturtle , Mar 8, 2019 :
    any one encounter phone dialer problem. after the 9.0.4 update, the phone dialer crash every time I hot the green dialer icon .
  13. BaconBoi
    Cupcake Mar 8, 2019
  14. G_Jaspreet_Singh_zNVl
    Donut Mar 8, 2019
    G_Jaspreet_Singh_zNVl , Mar 8, 2019 :
    My phone is all messed up after the updated. Since Pie update, my 5T (8gb + 128GB) keeps on crashing.
    WhatsApp, Dialler, Bluetooth, Mobile Network, Google Keyboard everything is crashing. Every second day, I need to clear Cache through the Recovery mode.
    The device heats up like oven while playing games. Battery backup is average.
    Sometimes SD 835 is working like Intel Pentium ii and hangs on basic operations.
    Can anyone assist me on how to fix this. it's was working as charm on Oreo but since PiE update it's causing trouble.
    Thanks in advance for any help.
    Dawestcoastboy likes this.
  15. roy_rod
    Cupcake Mar 8, 2019
    roy_rod , Mar 8, 2019 :
    Phone Dialer App Crashes everytime.
    Also messed up Contacts UI when adding a new contact.
  16. suraj_97
    Donut Mar 8, 2019
  17. volverOP5T
    Honeycomb Mar 8, 2019
    volverOP5T , Mar 8, 2019 :
    could you please provide steps for that. Factory reset without affecting internal storage and apps?
  18. G_Kishore_Jain_aEua
    Cupcake Mar 8, 2019
    patilpr likes this.
  19. neels_92
    Cupcake Mar 8, 2019
    hoanbt and G_Kishore_Jain_aEua like this.
  20. Harsha Vendra
    Froyo Mar 8, 2019
    Harsha Vendra , Mar 8, 2019 :
    Worse Update Ever Camera Quality Too Worst I Want To Degrade To 9.0.3 Any Suggestions Guys Why Camera Picture Quality Decreasing For Every Update I Don't Like This Update Anyone Facing Same Issue Please Reply
