232
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. stevenchow
    Gingerbread Mar 8, 2019
    Naman Gohil likes this.
  2. Dpaladines
    Eclair Mar 8, 2019
    Dpaladines , Mar 8, 2019 :
    Does one have a network drop? It happens to me very often from oos 9.0.3 to the current 9.0.4
  3. S1535467167936
    Cupcake Mar 8, 2019
  4. S1535467167936
    Cupcake Mar 8, 2019
  5. DavisOp
    Cupcake Mar 8, 2019
    DavisOp , Mar 8, 2019 :
    When updating my phone, my Spotify changed completely, can't access the category where you can see all of your downloaded songs. Only thing available is a few artists (which I should have hundred of) and my playlists
    Anyone else have this problem ?
    Side note: checked the play store and there wasn't any updates for spotify
  6. S1535467167936
    Cupcake Mar 8, 2019
  7. G_Aleksandar_Karaivanov_
    G_Aleksandar_Karaivanov_ , Mar 8, 2019 :
    Download the full file zip.9.0.3, put it in memory and install. Data is saved.
    Download the software build for your device on this page. Please back up your data before flashing your device.
    Plug your phone into your computer and copy the downloaded .zip to your phone’s storage.
    After the .zip file is copied to your phone, go to 'Settings' - 'system update', click the 'settings' icon on the top right corner, choose 'Local upgrade', find the .zip file and click on 'Install' to confirm.
    The update takes about a minute (depending upon the file size), once done reboot your device to boot into the latest Oxygen OS.
    https://www.oneplus.com/bg/support/softwareupgrade/details?code=7 https://www.androidsage.com/2019/01...9-0-3-for-oneplus-5-and-5t-hotfix-ota-update/
  8. TombaUk
    Donut Mar 8, 2019
  9. sachkharb
    Ice Cream Sandwich Mar 8, 2019
  10. TombaUk
    Donut Mar 8, 2019
  11. PriyaJain1990
    Eclair Mar 8, 2019
  12. Trevor.Hawkes
    Trevor.Hawkes , Mar 8, 2019 :
    Look at the top of this page and you will see a search box. Just enter "dialer" and you will find the solution.
  13. Mukund760
    Mukund760 , Mar 8, 2019 :
    digital well being is exclusive to Pixel and Android one phones. Maybe in the future google will open it for every android phone. One Plus cannot do anything about it.
  14. NMG99
    Donut Mar 8, 2019
    NMG99 , Mar 8, 2019 :
    There is a bit of stutter when switching between apps and opening the app drawer and doing normal tasks.
  15. sachkharb
    sachkharb , Mar 8, 2019 :
    I have dialler but just when I clicked on that this error occurs.
  16. Q1545504703112
    Honeycomb Mar 8, 2019
    Q1545504703112 , Mar 8, 2019 :
    You can root your phone and flash the pixel experience ROM. You get digital well-being and it's generally alot better than oxygen os.
  17. NMG99
    Donut Mar 8, 2019
    stevenchow90 likes this.
  18. Trevor.Hawkes
    Yes but some people are getting this problem and if you search "dialer" the solution is there. Just open the first result, or the second.
  19. sachkharb
    I have done this.. nothing happens.
  20. T1533998691666
