232
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. Trevor.Hawkes
    Ice Cream Sandwich Mar 8, 2019
    Trevor.Hawkes , Mar 8, 2019 :
    Are you saying you searched and found the solution but it didn't work or are you saying you searched and nothing happened.
  2. TombaUk
    Donut Mar 8, 2019
  3. G_sujith_somala_FRZH
    Donut Mar 8, 2019
  4. cz56946899
    Donut Mar 8, 2019
    cz56946899 , Mar 8, 2019 :
    quite a number of apps unable to connect to internet via cellular network. But it works via WiFi connection.
  5. R1517471871279
    Cupcake Mar 8, 2019
  6. stevenchow
    Gingerbread Mar 8, 2019
    stevenchow , Mar 8, 2019 :
    I had same issue with you, so annoying...
    Naman Gohil likes this.
  7. Aziz_Amin_Oneplus
    Jelly Bean Mar 8, 2019
    Aziz_Amin_Oneplus , Mar 8, 2019 :
    Again I am posting so everyone please see it if they have the problem with the dialer:-
    For all who is facing dialer FC bug, I've found a workaround and it works just fine. Follow the following steps and you'll be good to go.
    1. Download the OnePlus Phone apk from https://www.apkmirror.com/apk/onepl...ase/oneplus-phone-4-1-0-android-apk-download/
    2. Install the apk and open it. It'll crash but don't worry.
    3. Again go to Phone's app info. Tap on three dots on top right corner. Click on uninstall updates and then click on OK.
    4. Open the phone app again. DON'T CLICK ON DIALER BUTTON TO OPEN IT. EXIT THE APP IMMEDIATELY AFTER OPENING IT.
    5. Again go to Phone's app info and force stop it.
    6. Now open the dialer and you'll be good to go.
    Tested on OOS 9.0.4 OnePlus 5T.
    R1517471871279 likes this.
  8. batking33
    Cupcake Mar 8, 2019
  9. H1551865321745
    Cupcake Mar 8, 2019
    H1551865321745 , Mar 8, 2019 :
    am using an one plus 5t .. and after updating the OS to the latest version am facing a serious issue my phone keeps restarting if use a big app for e.g PUBG or Adobe light room
    please reply me with a solution .. what can I do
  10. R1517471871279
    Cupcake Mar 8, 2019
    R1517471871279 , Mar 8, 2019 :
    Tq it's working
  11. F1511582884874
    Cupcake Mar 8, 2019
    F1511582884874 , Mar 8, 2019 :
    hola qué tal me podrían ayudar a como poder actualizar mi teléfono ya que termina de descargar el archivo y me pide reiniciar el teléfono pero no me deja sigue descargando y nunca se puede actualizar me podrían ayudar a como tengo que hacerle para que tenga esta actualización mi teléfono.
    gracias
  12. Aziz_Amin_Oneplus
    This is 9.0.4 stable thread not open beta thread, post the attachment in open beta thread.
    F1511582884874 likes this.
  13. W1516013327393
    Eclair Mar 8, 2019
  14. F1511582884874
    Cupcake Mar 8, 2019
    thank you friend but how can I update my phone to be with this version of Android 9.0.4 since my phone currently has 9.0.1
  15. D1552051027036
    Cupcake Mar 8, 2019
  16. JOAOQUINTA
    Eclair Mar 8, 2019
    JOAOQUINTA , Mar 8, 2019 :
    Hi all,
    anyone have noticed problems on GPS location after this update (9.0.4)?
    Waze and GMaps not detect any GPS signal. the icon of location active when the app open but no signal...
    thank you
    JQ
    L1552040029887 likes this.
  17. S1549455176617
    Cupcake Mar 8, 2019
    S1549455176617 , Mar 8, 2019 :
    hello sir or madam this is a message to be rectified imediately as the cast option is not working after I updated my one plus 5 device that is after a recent update
  18. S.k.krishnan
    Froyo Mar 8, 2019
    S.k.krishnan , Mar 8, 2019 :
    Will you also improving camera app in 5t? for example 4k 60fps and slowmotion video shooting in 1080. and is it possible?
  19. K1521223185846
    Cupcake Mar 8, 2019
    K1521223185846 , Mar 8, 2019 :
    9.0.4 improvement network stability
    but I think now network is so bad....
    I wish OnePlus setup this network issue
  20. marcusskyfall
    marcusskyfall , Mar 8, 2019 :
    How does a screenshot illustrate your issue? :)
