232
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. edcassaro
    Eclair Mar 11, 2019
    edcassaro , Mar 11, 2019 :
    Even reseting anos wipening everything, installing with a new account without restoring apps... lags still appears. I did i yesterday and yet today i got lags.
  2. edcassaro
    Eclair Mar 11, 2019
    wipe cache was enough on Oreo. on Pie NOTHING works to eliminate lags. That's why I will back to 5.1.7 on my op5t
  3. S.k.krishnan
    Froyo Mar 11, 2019
    S.k.krishnan , Mar 11, 2019 :
    ok.which model gcam is suitable for 5t.
  4. PriyaJain1990
    Eclair Mar 11, 2019
    PriyaJain1990 , Mar 11, 2019 :
    Bluetooth icon doesn't show in status bar. most people forget that there Bluetooth is on. Plz bring that feature back if the Bluetooth is on it should be showing in status bar.
  5. Aziz_Amin_Oneplus
    Jelly Bean Mar 11, 2019
    Aziz_Amin_Oneplus , Mar 11, 2019 :
    That is a feature of Android Pie if you don't want it then go back to Oreo.
    PokiX likes this.
  6. PokiX
    PokiX , Mar 11, 2019 :
    You are missing some points (my answer is in post #1256) especially when I mentioned to wait several full charges.
    Do not clear cache unless you have a very good reason. Clearing cache will create lag, the time that the cache is created.
  7. R1552261110141
    Cupcake Mar 11, 2019
    R1552261110141 , Mar 11, 2019 :
    Hi
    My only 3 months old oneplus 5t has just suddenly started crashing and rebooting itself after i updated the system to 9.0.4. anything i could do to make it stop rebooting randomly?
    because it is so annoying when it does it in middle of a call or something else important.
    I already have tried all the different fixes people suggest to others who have the same problems, like clearing cache, charging all night, factory reset and even tried to download the previous version (9.0.3) but nothing works.
    Please fix this Oneplus!
  8. PriyaJain1990
    Eclair Mar 11, 2019
  9. sachkharb
    Ice Cream Sandwich Mar 11, 2019
    sachkharb , Mar 11, 2019 :
    Oh yeah.. I am not rooted.. and I am using my GCam perfectly.. bt there is only 2 limitations.. I cannot use 'night sight and portrait mode' in front camera
  10. sachkharb
    Search GCam port in google.. open first link.
    Now u r ready to go.. if u have any prb.. then ask me
    Qwert Luiop and Paul_W_ like this.
  11. __sk__
  12. __sk__
    __sk__ , Mar 11, 2019 :
    earphone symbol ....when i connect earphone....then disconnecting..my erphone ..but not disconnecting and phone show the earphone symbol......its..... problem..i face....
  13. neha.252591
    neha.252591 , Mar 11, 2019 :
    same
  14. neha.252591
    by flash you mean i should download 5.1.7 android zip?? if yes from where can i download it?
  15. J1511487410217
    J1511487410217 , Mar 11, 2019 :
    some one suggest me to switch the phone off for 5 mins and then switch it on, and it stopped blinking
    neha.252591 likes this.
  16. neha.252591
    Yes , it did work for me as well. Though phone is still slow.
    Thanks Alot
    J1511487410217 likes this.
  17. J1511487410217
    have fun with your updated phone
  18. L1517081361762
  19. anupritaisno1
    KitKat Mar 11, 2019
    anupritaisno1 , Mar 11, 2019 :
    Actually it's not
    You might not be aware the Google has made it compulsory for manufacturers to ensure that system upgrades don't require anything like wiping data or cache
    This is what happens when you do not read the error
    For TWRP flashing errors the error code is useless. Read the message above the error
    The error says "cannot create file on /cache" so you had to just format cache
    Wiping dalvik-cache was wasteful
    Well TWRP is based off the stock AOSP recovery and it works. Stop spreading misinformation
    Wiping cache is never the solution. Ask @PokiX why
  20. T1515122947551
    Eclair Mar 12, 2019
    T1515122947551 , Mar 12, 2019 :
    any suitable gcam for one plus 5?
