232
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. Roshan Dcosta
    Donut Mar 18, 2019
    H1523943365411 likes this.
  2. DNS2002
    Eclair Mar 18, 2019
    DNS2002 , Mar 18, 2019 :
    Hi all,
    Upgraded my OP5 from 9.0.3 to 9.0.4 after 2 weeks or so.
    After a full day of general use, i have not come a cross any issues.
    1. Battery life is almost same as 9.0.3.
    2. No app crashing, specially dialer app.
    3. No connectivity issues.
    Apart from above there is a browsing lag between frames which is happening intermittently. This was there in 9.0.3. And for me its not a major issue.
    Hope there will be another fix soon for the lags.
  3. cybersa
    Gingerbread Mar 18, 2019
  4. G_jose_saju_kYGZ
    Cupcake Mar 18, 2019
    G_jose_saju_kYGZ , Mar 18, 2019 :
    update is well and good but don't know at times the UI lags(a slower animation ) and takes a few moments to come back to its proper animations
    anandsiddharth and Kaizen10 like this.
  5. Ganeshbhavsar11
    Ganeshbhavsar11 , Mar 18, 2019 :
    Finger print sensor is not working correctly.
    same bug was reported in previous update also.
    OP please help to get stable update soon...
  6. rnrocks7
    rnrocks7 , Mar 18, 2019 :
    I am a 5t user after this update some times when I try to open my camera it does not work it gives a message that "failed to open camera".
    this issue comes repeatedly. then I need to restart the phone to make it work fine .
    I hope you all will look into this and will help me to get this corrected.
  7. ouyamaster
    Honeycomb Mar 18, 2019
    ouyamaster , Mar 18, 2019 :
    DNS2002
    Hi all,
    Hope there will be another fix soon for the lags.​
    Are you fully stock? No bootloader unlock custom kernels or changes?
    Ronnie11 likes this.
  8. Brian Meyers
    Donut Mar 18, 2019
    Brian Meyers , Mar 18, 2019 :
    Does this version still have the god awful dark tint on the lock screen. If it does I will just stick with 8.1
  9. ouyamaster
    This is Experimental and can brick your phone so anyone who attempts it be forewarned.
    If you cannot afford to clean wipe if you brick do not try this. I plan on trying this in a week or so and if I brick I'll just clean wipe.
    I'll attempt to dirty flash the rom 9.04 pie from one plus site with siankatagb twrp 3.2..3 based on Blu spark.
    If anyone can afford to potentially brick and clean wipe but if this possibly works may not have to. try it out and report back. Not that this means it still won't brick someone else but the success rate on this would be good to know.
    https://forum.xda-developers.com/on...very-twrp-3-2-3-pie-encryption-t3837342/page1
  10. kidjt94
    Froyo Mar 19, 2019
    kidjt94 , Mar 19, 2019 :
    I've tried that recovery too, it decrypts, but fails with treble error.
  11. ouyamaster
    Honeycomb Mar 19, 2019
    ouyamaster , Mar 19, 2019 :
    kidjt94
    Thanks for letting me know.
    Did you try all of the other 4 variants in the link also?
    I might try for the heck of it.
    you probably didn't brick just got the usual treble corrupt zip errors.
    Has anyone out there tried fresh wipe clean installs with any of these recoveries?
    I'm curious if it will work or not?
  12. kidjt94
    Froyo Mar 19, 2019
    I tried both treble and non treble for pie.
    I didn't brick, just got the treble errors.
  13. ouyamaster
    We need someone who doesn't mind to clean wipe and reinstall everything.
    if it still doesn't work might as well stay on 9.03 for now.
  14. kidjt94
    Froyo Mar 19, 2019
    looks like I'm going to have to.
    I just hate the update icon lingering in my notifications bar.
  15. ouyamaster
    I hear ya.
    report back if it's successful.
    That will help me decide to live with the update nag or clean wipe myself also next week when I have time.
  16. V1508521955148
    Eclair Mar 19, 2019
    V1508521955148 , Mar 19, 2019 :
    Hi Team,
    I don't see File manager option after this upgrade. if anyone facing the same issue.
    Regards, Venkat
  17. DNS2002
    Eclair Mar 19, 2019
    DNS2002 , Mar 19, 2019 :
    Yes, Fully stock, no BETAs, only OTAs. And i never do a cache clearing before updating, as my understanding is "Cache" is a precious thing when you build up the APPs usage pattern for power management.
  18. VangelisKps
    Eclair Mar 19, 2019
    cybersa likes this.
  19. cybersa
    Gingerbread Mar 19, 2019
    cybersa , Mar 19, 2019 :
    Today i got new update for "Wear OS" app from play store , after this update its started to work fine. Seems like issue with Google Wear Os app. Thanks for the information.
  20. Mr_Cyrox
    KitKat Mar 19, 2019
    Mr_Cyrox , Mar 19, 2019 :
    I'm pretty sure the lockscreen tint is here sence Oreo...
