232
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. HadiFab
    Eclair Mar 19, 2019
  2. Kum1r
    Eclair Mar 19, 2019
    Kum1r , Mar 19, 2019 :
    some time mobile is switched off automatically after updated 9.0.4. what will the issue can any one support
    rasulkhan7 and arpit1+ like this.
  3. zaveed
    Cupcake Mar 19, 2019
    zaveed , Mar 19, 2019 :
    Happens with me twice in a day atleast and i only get to know when i have to enter the PIN after restart. I have 11 bug reports so far an d doubt if these would be looked into anytime so did not send it :(
    rasulkhan7 likes this.
  4. Rohan_S_P
    Honeycomb Mar 19, 2019
    Q1545504703112 likes this.
  5. nick_k
    Gingerbread Mar 19, 2019
  6. Q1545504703112
    Q1545504703112 , Mar 19, 2019 :
    I feel like OnePlus' development team isn't aware of the issue as it had persisted for over three months now. The only thing to do is roll back to 5.1.7 or use a custom rom
  7. prat_brat
    Froyo Mar 19, 2019
    prat_brat , Mar 19, 2019 :
    Why is there a big gap between the Icons and the bottom of the screen, this is for the OP 5T.
    I think the Gap is bigger than the one in Oreo, 5.1.7.
    Don't know if it's a big issue or not.
  8. Q1545504703112
    Are you using navigation gestures?
  9. Z1553013302054
    Z1553013302054 , Mar 19, 2019 :
    The last time I updated my phone with the new oxygen os 9 that launched for one plus 5 that ended up in corrupting the motherboard of my phone.
    I am too scared to go with this or any system update that comes moving forward.
    can anyone let me know if they faced any such issue with this hotfix update.
  10. prat_brat
    Froyo Mar 19, 2019
    Yes, I am using the Navigation Gestures.
    When I used them in Oreo, the difference wasn't that big, that's why I am asking.
  11. Rohaan_shaikh
    Eclair Mar 19, 2019
  12. Rohan_S_P
    Rohan_S_P , Mar 19, 2019 :
    download full rom and flash the zip file.
    After that you need to clear data.
  13. Q1545504703112
    First disable the gestures and then enable them again. The gap is there to house you onscreen navigation buttons.
  14. prat_brat
    Froyo Mar 19, 2019
    There isn't a place to enable and disable, you just have to choose from the 3 options in the Buttons & Gestures page.
    I chose different options and went back to the 3rd option, and still the same.
  15. O1518202119073
    Donut Mar 19, 2019
  16. prat_brat
    Froyo Mar 19, 2019
    Q1545504703112
    Look at this.
    Can you see the difference and the gap from the bottom of the screen. It's quite huge, looks like a bug to me.
    This is another with the pill, and still the same gap from the bottom.
  17. Q1545504703112
    Maybe update oneplus launcher or force stop it. If that still doesn't work change your launcher or submit a bug report
  18. prat_brat
    Froyo Mar 19, 2019
    Q1545504703112
    Maybe update oneplus launcher or force stop it. If that still doesn't work change your launcher or submit a bug report​
    Okay will try what I can, if it doesn't work, I'll submit the bug report.
    Thank you.
  19. ouyamaster
    ouyamaster , Mar 19, 2019 :
    One other issue if we can't flash a treble rom with twrp. We might be able to clean wipe then downgrade back to Oreo or use a custom Rom.
    However what if we cannot reinstall any pie version through twrp. that will suck. Still undecided what to do. It would be good to know if anyone can ever flash 9.04 with a clean wipe through any version of twrp. And we need to know which one.
  20. venioni
    Froyo Mar 19, 2019
