232
OxygenOS 9.0.4 OTA for OnePlus 5 and OnePlus 5T
  1. Gauravgiri
    Eclair Mar 22, 2019
    Gauravgiri , Mar 22, 2019 :
    9.0.4? Yes.
    Deactivated User likes this.
  2. Deactivated User
    Mar 22, 2019
  3. ouyamaster
    Honeycomb Mar 22, 2019
  4. sachkharb
    Ice Cream Sandwich Mar 22, 2019
  5. ouyamaster
    ouyamaster , Mar 22, 2019 :
    Another dumb question because the twrp 9.96 is a cheese burger recovery. Will it be safe to use with 5T dumpling and have you ever used a cheeseburger recovery on dumpling?
  6. ouyamaster
  7. ouyamaster
  8. batking33
    Cupcake Mar 22, 2019
    batking33 , Mar 22, 2019 :
    auto rotate and auto brightness are feeling like gimmicks with this ota. they seem to do whatever they wanna do. brightness sometimes take like two three tries to figure out if it wanna increase itself then go back to original.
  9. L1553057257105
    L1553057257105 , Mar 22, 2019 :
    hi I'm facing fast battery drain issue in 9.0.4. when i charge my phone to 100 percent it drains 8 percent in almost 10 mins. after that it works normal. can anyone help me with this?? I'm getting 5-5.30hrs of sot with moderate usage.
  10. batking33
    that's how they wanted it to work. it will help your battery maintain its lifespan for in a long run.
  11. L1553057257105
  12. L1553057257105
  13. L1553057257105
  14. PokiX
    Jelly Bean Mar 22, 2019
    PokiX , Mar 22, 2019 :
    It is rather complex to get the realtime capacity of a battery from external sensing. When it hits 100% don't rush to unplug it, leave it an hour.
    What counts is the overall time since last charge and screen on time.
    And that these timings are not comparable from one user to another.
    I get 5h to 8h SOT over two days.
  15. L1553057257105
  16. zach.perlman
    Eclair Mar 22, 2019
    zach.perlman , Mar 22, 2019 :
    Has anyone noticed that swiping down on the fingerprint scanner for notifications no longer works? Also when I search for it in settings, the search option shows up but the actual option/ability to turn it off and on is gone.
  17. zach.perlman
    Eclair Mar 22, 2019
    Even more strange, it now works! But the option is still gone from settings! No idea what's going on here
  18. zach.perlman
    Eclair Mar 22, 2019
    After some investigation it seems they just moved the option to a new menu and forgot to fix the search function. It is no longer located in quick gestures (as it used to be) and is instead one level earlier
  19. captvnrao
    captvnrao , Mar 22, 2019 :
    it does exists...in 9.0.4
    zach.perlman likes this.
  20. captvnrao
