194
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. astralbee
    Ice Cream Sandwich Oct 24, 2019
    astralbee , Oct 24, 2019 :
    Sorry to brag about Lineage again but it's been the best decision I made. OTA updates that are non-destructive - you don't even lose root when you update. Battery life better by the day. Loving my OP3 again.
    George Kessaris likes this.
  2. fouadmordi
    Gingerbread Oct 24, 2019
    fouadmordi , via OnePlus 3 , Oct 24, 2019 :
    it's sad that when people phone get slower and buy directly a new phone and dont know about custom roms...
    astralbee likes this.
  3. Fhdshahzad
    Gingerbread Oct 25, 2019
  4. G_Adrian_Vraciu_iWyl
    Cupcake Oct 25, 2019
    G_Adrian_Vraciu_iWyl , Oct 25, 2019 :
    How about camera? Quality is the same as of official rom?
  5. Slavomir Latka
    Eclair Oct 25, 2019
    Slavomir Latka , Oct 25, 2019 :
    Go on XDA, there are lot of custom ROMs. You will need unlock bootloader and replace recovery with TWRP.
    Then you are able to install custom ROMs
  6. Fhdshahzad
    Fhdshahzad , via OnePlus 3 , Oct 25, 2019 :
    Thanks for the response.
  7. Slavomir Latka
    Eclair Oct 25, 2019
  8. G_karam_horane_RGxt
    G_karam_horane_RGxt , Oct 25, 2019 :
    hi i have i Question after Pie updates problem i wanted to use custom rom and usb port doesn't work with otg or computers so i couldn't unlock the bootloader is there any way of unlock it ?
  9. ghostofcain
    Marshmallow Oct 25, 2019
    ghostofcain , Oct 25, 2019 :
    You can access ADB, not sure about bootloader, over wi-fi, But I wouldn't recommend trying to flash a ROM of any sort without a fully functional device.
    Pradeep@1+ likes this.
  10. fouadmordi
    fouadmordi , via OnePlus 3 , Oct 25, 2019 :
    the custom rom name is nitrogen
    install the latest firmware oos 9.0.5 the do a backup of the rom and place it on a pc then download the rom and open gapps 10 beta nano and magisk then wipe data system caches and install then when you finish go to format and hit yes and then it will reboot
  11. nadeem199417
  12. astralbee
    Ice Cream Sandwich Oct 25, 2019
    astralbee , Oct 25, 2019 :
    That's one thing I'm still experimenting with. Photos seem fine, the camera opens quickly. Video also seems good. It has a 4K mode but I can't see a 60hz mode. The only thing I'm not sure about is the audio quality, but that may be what I'm hearing rather than what's recording. Lineage has built-in audio FX and I haven't played with that yet.
    I'm looking into the Google camera and also any oxygen camera rips.
  13. astralbee
    I'm fairly certain you can't go through the whole process of unlocking and installing TWRP without USB, but even if you could, I wouldn't. If anything goes wrong you definitely need a working usb connection to unbrick.
    But if your usb doesn't work, how do you charge? There's a few things I'd check.
    1. Check the usb preferences in settings. You can set the behaviour when a connection is made, maybe it's set to only charge?
    2. Make sure adb over usb is enabled in developer options. You have to enable developer options to see them.
    3. Give your usb port a good clean. There might be 3 year's worth of pocket lint in there. Give it a gentle scrape out with a wooden or plastic toothpick. Don't stick anything metal in there.
  14. X1572063147080
    Cupcake Oct 26, 2019
    X1572063147080 , via OnePlus 3T , Oct 26, 2019 :
    I didn't got Android P update till now on my OnePlus 3T
  15. Ashyam
    Froyo Oct 26, 2019
    Ashyam , via OnePlus 3 , Oct 26, 2019 :
    you should thank your situation... Android P is not smooth and ther bugs till date
  16. X1572063147080
  17. Pradeep@1+
    Ice Cream Sandwich Oct 26, 2019
    Pradeep@1+ , via OnePlus 3 , Oct 26, 2019 :
    It seems all are adapting themselves in their own ways whether custom ROM or older OOS with OP3/T. Better to settle one as it's almost EOL hardly can expect one or maximum two updates i guess.
    mohd_areeb likes this.
  18. capriady78 and Kalyan like this.
  19. Auristic
    KitKat Oct 26, 2019
    Auristic , Oct 26, 2019 :
    Bye then and have fun in the Samsung forums asking either for help or for updates! :p
    Pradeep@1+ and mohd_areeb like this.
  20. G_Shri_Harsha_KkSL
