137
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. astralbee Ice Cream Sandwich Aug 13, 2019
    astralbee, Aug 13, 2019 :
    Anyone else getting phantom screenshots taken in this update???
    I keep finding that I've got notifications saying I've that taken screenshots I haven't taken. And it's not easy to accidentally press and hold two buttons on opposite sides of the phone. This has never happened before but it's happened at least 6 times since updating. I've checked that gestures are turned off, which they always have been since the day I bought the phone.
    I may have spoken too soon about this rom being perfect.
  2. uarvshi19790 Froyo Aug 13, 2019
  3. ghostofcain Marshmallow Aug 13, 2019
    ghostofcain, Aug 13, 2019 :
    What would possible possess you, if annoyed at OnePlus buggy updates, to buy a newer phone from them?
    OP not read either.
    Prattech and Fhdshahzad like this.
  4. D1562240269627 Cupcake Aug 13, 2019
  5. G_Gabriele_Bocci_ltGH Gingerbread Aug 13, 2019
    G_Gabriele_Bocci_ltGH, Aug 13, 2019 :
    Hello, I think too it's all a software problem the issues you've described, hardware should be enough even for Q, that's way P should run smoothly and cooler. I just hope they don't wanna destroy our immortal OP3 via software bugfix [e]1f602[/e]
    For a cooler OP3/3T \m/
  6. Andrei R. Ice Cream Sandwich Aug 13, 2019
    Andrei R., Aug 13, 2019 :
    It's not press and hold anymore. It's just press both buttons and the screenshot is taken. At least that's what I figured out after Pie update
    Praty_28 likes this.
  7. xythiii Ice Cream Sandwich Aug 13, 2019
    xythiii, Aug 13, 2019 :
    This update made my phone an oven....it gets very hotttt, times to times and it's annoying....
  8. PickleRick Cupcake Aug 13, 2019
    PickleRick, Aug 13, 2019 :
    I'm
    I'm a not against formatting my device but what is the absolute best way to backup everything on my non rooted 3T
  9. F_Prashant_Karmacharya_U Honeycomb Aug 13, 2019
    F_Prashant_Karmacharya_U, Aug 13, 2019 :
    oneplus switch
  10. abhyaung_havale Froyo Aug 13, 2019
  11. PickleRick Cupcake Aug 13, 2019
    Can't figure out how to backup off device, seems i have to back to the device first.
    It is possible to point to something like drop box
  12. ghostofcain Marshmallow Aug 13, 2019
    Clean your port, swap your cable and plug etc. It's not the update.
    remjes likes this.
  13. sammerasker Ice Cream Sandwich Aug 13, 2019
    sammerasker, Aug 13, 2019 :
    That's how it always worked, you root with every update
    Meet@321 likes this.
  14. praveenmk109 Cupcake Aug 13, 2019
  15. Blue-agila Ice Cream Sandwich Aug 13, 2019
    Blue-agila, Aug 13, 2019 :
    Yes.. Its not your turn yet
  16. rich2e Froyo Aug 13, 2019
    rich2e, Aug 13, 2019 :
    I used a VPN the very first day 9.0.5 was released and was able to OTA update that day.
  17. combatqueen Cupcake Aug 13, 2019
    combatqueen, Aug 13, 2019 :
    First let me say how much I love this phone and how fast it moves and how amazing my game graphics are. I actually just bought this phone, used, a few weeks ago after looking at a lot of reviews and still can't believe that it gets the latest Android Op. I did notice the fast battery drain and over heating while gaming, but this last update, with some apps has def helped with that. I don't like that there isn't a setting to keep the phone wake. I did find an app to help with this, so it's working great now. Overall it was worth the buy. Absolutely in love with this phone. I'll be staying with OnePlus from now on
  18. astralbee Ice Cream Sandwich Aug 13, 2019
    You're right. What a stupid and pointless change.
    Although that doesn't explain how I'm only noticing all these pocket screenshots since the latest update. Are you sure this is the case since the first iteration of Pie??
  19. xishanaliraza Cupcake Aug 13, 2019
    xishanaliraza, Aug 13, 2019 :
    updated to 9.0.5 three days ago
    No heating (not even on 9.0.4)
    No battery Drain (not even on 9.0.4)
    No hanging (not even on 9.0.4)
    Known Issues
    images from oneplus camera are not blurry but extra smothed so it not look like as sharp as 16mp image have to be
    hanged severytime for few sec (1-2) when turned on Bluetooth (on 9.0.4 it will take about 5sec)
    call screen showing time is better then 9.0.4 butt sill there
  20. Q1565511926206 Cupcake Aug 14, 2019
    Q1565511926206, Aug 14, 2019 :
    yea for me too..
