139
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. OLS_TheWho Gingerbread Aug 14, 2019
    OLS_TheWho, Aug 14, 2019 :
    Jep, feels like. Unlock via Fingerprint takes longer, Apps are getting opened slower and the phone uses more energy than before.
    but I have to be fair. My phone is a 3T and in use since it got released. Might be the accumulator does slowly.
  2. Khansa_Zahed Gingerbread Aug 14, 2019
    Khansa_Zahed, Aug 14, 2019 :
    thanks!
  3. Pepsican Froyo Aug 14, 2019
    Pepsican, Aug 14, 2019 :
    I don't think your phone uses more power (other than perhaps due to swapping). Probably more likely that your battery is showing its age and doesn't hold power as well as it used to.
    Also, the apps you installed three years ago have grown in size due to the addition of new features. You probably use more of them as well (I have over 100 apps installed by now). And most apps build up cache data over time, making them larger still. But your memory has stayed constant, so your phone probably swaps more data around between storage and memory, making your phone feel less responsive.
    Milind.Deval likes this.
  4. prakashghimire Cupcake Aug 14, 2019
    prakashghimire, Aug 14, 2019 :
    My phone restart all of sudden and can't start the phone. It keep restarting. I have restore the phone. But issue isn't resolved.
  5. E1564860453839 Cupcake Aug 14, 2019
    E1564860453839, Aug 14, 2019 :
    D
    Did so many time But nothing is working only shows me the wifi that are 2.4ghz band. and not I normally Use emulators and type on mobile and there are many different apps and all of them shows the same behaviour.
  6. E1564860453839 Cupcake Aug 14, 2019
    Its not like phone hanging its more like touch missing.
  7. Q1565511926206 Cupcake Aug 14, 2019
    Q1565511926206, Aug 14, 2019 :
    hey
    it's been one week and how's battery performance?
    pls share
  8. harsh_1203 Cupcake Aug 14, 2019
  9. Q1565511926206 Cupcake Aug 14, 2019
    how's the battery performance bro?
    pls share
  10. OLS_TheWho Gingerbread Aug 14, 2019
    Might be. I don't have that many Apps installed but they are installed for a long time.
  11. uarvshi19790 Froyo Aug 14, 2019
  12. shantanucse18 Froyo Aug 14, 2019
    tsyoma likes this.
  13. Sadra_Imam Gingerbread Aug 14, 2019
    Sadra_Imam, Aug 14, 2019 :
    The battery usage is around 6 hours SOT with casual gaming, voice call and watching online videos. I should mention that I'm mostly connected to WiFi and mobile data is turned off all the time.
    I haven't experience any heavy battery drain or heating yet.
    yesterday the phone started to lag and I had to restart the phone to fix it. it was only that one time. not sure what's the reason behind it, can be hot weather as well or some heavy background activity.
    something I noticed is "Google Play Service" keeps waking up the phone and show screen off notifications which start looking for location every hour or so. it seems I have an app installed or there's a setting somewhere causing this behavior.
    I didn't find enough time to find the exact reason, I just removed access to location for most of my apps.
    Anyhow it doesn't affect my battery that much.
    in conclusion: 9.0.5 still need alot of optimization regarding app background activity and battery optimization. so far UI is smooth and battery usage is acceptable, except some minor issue every few days which can be solved by simply restarting the phone. still you won't be as satisfy as 5.0.8 (almost perfect daily driver ROM).
    Q1565511926206 likes this.
  14. shantanucse18 Froyo Aug 14, 2019
    shantanucse18, Aug 14, 2019 :
    Stand by is good, still testing average uses battery performance, oreo is better until now.
  15. GIORGOS STAMOULIS Cupcake Aug 14, 2019
  16. Z1565668251124 Cupcake Aug 14, 2019
  17. F_David_Balen_Sandstedt_ Cupcake Aug 14, 2019
    parth.panchal likes this.
  18. manas_aswal Cupcake Aug 14, 2019
    manas_aswal, Aug 14, 2019 :
    Some bugs regarding battery life and laggy performance have still not been sorted out.Seems like the 3 and 3t are unable to cope with the android pie update.
  19. parth.panchal Donut Aug 14, 2019
    parth.panchal, Aug 14, 2019 :
    I received this update. It has some very annoying bugs. Display is waking 5-6 second after ring has started. If I am listening songs in gaana Music app then it's notifications is not displaying in notifications bar. Battery is draining very fast. You have to charge 3 times in a day. What to do with these bugs. Instead of new release previous one was batter.
  20. U1565576730638 Cupcake Aug 14, 2019
