194
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. D1564335250345
    Donut Aug 16, 2019
  2. C1533631492584
    Cupcake Aug 16, 2019
  3. D1564335250345
    Donut Aug 16, 2019
    D1564335250345 , Aug 16, 2019 :
    w cm
    also can google any file ...many website have these files....& follow instructions to downgrade....make sure backup ur data.
  4. SamMoses
    Froyo Aug 16, 2019
  5. Siddhardha babu K
  6. D1564335250345
    Donut Aug 16, 2019
    download oxygen updater & update from it
  7. Siddhardha babu K
    Siddhardha babu K , Aug 16, 2019 :
    The same issue, i am facing in current version also. 9.0.4
  8. mikica023
    Honeycomb Aug 16, 2019
  9. DailyLama72
    Eclair Aug 16, 2019
  10. Auristicpleaseignoreme
    Gingerbread Aug 16, 2019
  11. Nishankrathore
    Eclair Aug 16, 2019
    Nishankrathore , Aug 16, 2019 :
    screen donot on there is delay while incoming call when this bug will fiz. i m fedup of this glitch. who else face this issue in 9.0.5 its not fixed i do not know what bugs have been fixed.
  12. Mr.Anon
    Mr.Anon , Aug 16, 2019 :
    Hi!
    I just updated from OxygenOS 5.0.8 to 9.0.5 doing a factory reset and i no have major issues BUT:
    - Fingerprint unlock is clearly slower than before
    - Double tap to turn on the screen, it takes more time respect to Oreo
    - In calls the screen has about 1.5 seconds of lag since it starts ringing
    I hope these things can be improved in a future update
    Thanks
    thevuman likes this.
  13. Milind.Deval
    Milind.Deval , Aug 16, 2019 :
    Issue resolved after resetting phone theme. The new phone dialer app is running fine.
  14. Andrei R.
    Ice Cream Sandwich Aug 16, 2019
    Andrei R. , Aug 16, 2019 :
    Where did you find this option?
  15. Rui Delgado
    Froyo Aug 16, 2019
    Rui Delgado , Aug 16, 2019 :
    Just for those who are thinking in update from Oreo to Pie...
    I was skeptical of updating the phone because there are several users reporting bugs. Even so I decided to give it a try and could not be more pleased. No problems with the fingerprint sensor (fast as always), no screen delays on incoming calls, BT works very well and all that bothers me is the status bar hidden and the need to slide down on the screen to see the bar (is there any way to have it always visible, as in Oreo?)
    The battery is still unstable due to use so it is early to speak. It should be said that I did a full cleanup on the upgrade (I formatted everything including internal storage and system). Until now I'm happy with the decision
  16. P1555919653374
    Eclair Aug 16, 2019
  17. I1560757516685
    I1560757516685 , Aug 16, 2019 :
    All pie versions have worked fine in my OP3 including 9.0.5. No slowdowns , problems with calls or battery draining. How can people with similar hardware can have so different behavior in their phones. I haven't done a factory reset or cache cleaning . This my geekbench results dunno if its ok for the device ?
    r.hutton likes this.
  18. DonHartnett
  19. sanjay7465
    sanjay7465 , Aug 16, 2019 :
    Today I received 3rd update for Android Pie but still a major bug of call conferencing is there.
  20. sanjay7465
    @Manu J.
    From the day I received Android 9 update, I am not able to make conference call. Later on I received one more update, that didn't fix the issue. I provided the logs and other details as requested by Oneplus and today I received 9.0.5 update with the same bug and the change logs says
    1. Updated security patch to 2019.8
    2. General bug fixes.
    Why Oneplus is not looking for this major bug?
