194
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. Paschfire
    KitKat Aug 7, 2019
    Paschfire , Aug 7, 2019 :
    OnePlus3TOxygen_28_OTA_085_all_1907311943_3c4d77566c8.zip
    #61
  2. Some_Random_Username
    Community Bug Hunter Aug 7, 2019
    #62
    Bighnesh, Guyco42, Paschfire and 2 others like this.
  3. G_Michał_Korcz_bNTq
    Eclair Aug 7, 2019
    #63
  4. ColinMcDrei
    Gingerbread Aug 7, 2019
    ColinMcDrei , Aug 7, 2019 :
    We expect them to fix this bug, so that unlocked Oreo users can finally Update to Pie!
    #64
  5. AnuGeorge
    AnuGeorge , Aug 7, 2019 :
    I got the OTA it's 291mb installed it's working fine for now will check and update any bug and battery performance further info thanks 1+ for supporting.
    #65
    frazzaglia and Gaizka Ayo like this.
  6. Tim1987NL
    Cupcake Aug 7, 2019
    #66
  7. Some_Random_Username
    Some_Random_Username , Aug 7, 2019 :
    Thanks, adding it as well
    #67
  8. astralbee
    Ice Cream Sandwich Aug 7, 2019
    astralbee , Aug 7, 2019 :
    Got it, VPN to Germany. Don't forget, if you choose to download it that way using the system update feature:
    (i) you can disconnect the vpn the moment it starts downloading, which will likely be faster
    (ii) if you are rooted and want to stay that way, once the update is downloaded you can use a root explorer to move the file from the .ota folder to your usual download folder then reboot into twrp and flash it from there using the usual steps to retain root.
    #68
  9. bupapa
    Eclair Aug 7, 2019
    bupapa , Aug 7, 2019 :
    You are so right
    #69
  10. Sadra_Imam
    Sadra_Imam , Aug 7, 2019 :
    Thanks for the heads up.
    VPN to Germany worked for me. I'm downloading it right now.
    #70
    astralbee likes this.
  11. TheMystic
    Lollipop Aug 7, 2019
    #71
    HavnFunHere and Praty_28 like this.
  12. Singhji21
    Honeycomb Aug 7, 2019
    #72
  13. bupapa
    Eclair Aug 7, 2019
    #73
    JaviAC likes this.
  14. G_Kostja
    Froyo Aug 7, 2019
    #74
    HavnFunHere, m.parvage and JaviAC like this.
  15. croniccorey
    Eclair Aug 8, 2019
    #75
    HavnFunHere likes this.
  16. RRAlex
    Cupcake Aug 8, 2019
    RRAlex , Aug 8, 2019 :
    Seriously, why was it working since the beginning and now we're screwed?
    If I relock I'm going to have to reinstall everything which I'm not backuping in the cloud or I'd be buying pixels...
    Unless someone has an easy backup -> lock -> restore -> upgrade procedure?
    #76
    PTuT likes this.
  17. netllocke
    Ice Cream Sandwich Aug 8, 2019
    #77
  18. F_Mat_Complicated_ZZDb
    Cupcake Aug 8, 2019
    F_Mat_Complicated_ZZDb , Aug 8, 2019 :
    #78
  19. F_Mat_Complicated_ZZDb
    Cupcake Aug 8, 2019
    #79
  20. Deactivated User
    Aug 8, 2019
    #80
