191
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. F_Jose_Chamoso_Poveda_EW
    Cupcake Aug 18, 2019
  2. AndyRadikal
    Froyo Aug 18, 2019
    AndyRadikal , Aug 18, 2019 :
    en la configuración ingrese a la pantalla, busque "tema" y seleccione "tema oscuro"
  3. F_Jose_Chamoso_Poveda_EW
    Cupcake Aug 19, 2019
    F_Jose_Chamoso_Poveda_EW , Aug 19, 2019 :
    Gracias por contestarme
    Ya está el fondo en negro era muy incómodo como me había quedado.
    De momento todo lo veo bien.
    Un saludo
  4. Ashish_K.
    Eclair Aug 19, 2019
    Ashish_K. , Aug 19, 2019 :
    storage won't get wiped if you do via OTA. however it is recommended that you perform a factory reset after installing pie,just so that caches don't create bugs
  5. ashwin6056
    ashwin6056 , Aug 19, 2019 :
    Recently updated my 3T with 9.0.5. Facing the following two issues so far:
    1. Unable to select options from notification panel. eg. when alarm rings we get two options in notification (snooze, dismiss). When we tap on any of these options the app itself opens instead of the intended action. Its happening for all app notifications.
    2. Automatic brightness has become over sensitive and change too frequently indoor. Even a slight tilt of phone will change brightness based on light conditions which is irritating.
    Is it only me or everyone is facing these issues in the latest update ?
    Support team kindly fix these issues soon.
  6. G_Ajay_Panigrahi_dIGd
    Donut Aug 19, 2019
  7. 悬崖不勒马
  8. Hemant52
  9. O1521668246656
    O1521668246656 , Aug 19, 2019 :
    Did a 100% clean install because my bootloader was unlocked and can't complain about anything important. Battery is better than before, performance very fast and without issues. Sometimes the camera don't focus that good and the fingerprint take some seconds. If this two things get fixed the Rom is even better than Oreo. Overall a very good update
  10. S1524149544966
  11. O1566058695857
  12. AndyRadikal
    Froyo Aug 19, 2019
    AndyRadikal , Aug 19, 2019 :
    Not possible coz of the op firmware too much conservative, you have to install an alternative ROM with a nice firmware on it
  13. tadebruijn
    tadebruijn , Aug 19, 2019 :
    Previous update to android P made my OnePlus 3 initially slower and caused some level of battery drain (roughly 1.5-2h SOT). After a simple reboot both seem to be improved. After this 9.0.5 update the phone feels smooth and battery life (roughly 3-3.5h SOT) seems to be good again.
    Thanks for the long lasting support!
    P.S. does this update include the security patch of the 5th of August fixing the KNOB issue?
    Edit: note, last week's I was most of the time on WiFi
  14. PindurPandur
    Gingerbread Aug 19, 2019
    PindurPandur , Aug 19, 2019 :
    I'm not so happy that they screwed up LED notifications with Pie update as well as the GPS. Countless feedbacks on the problems and still nothing is better with the 5th (?) update.
    I'm not angry, rather sad.
  15. abhitour
    mohd_areeb and AndyRadikal like this.
  16. T1517204557377
    T1517204557377 , Aug 19, 2019 :
    When ever i silent my phone the incoming cal notification completely disappears from the phone. Not even shown in the notification tab. Again i need to wait sometime for it to reappear and the cal doesnt hang up even after using the cal end button for twice and the cal notification still remains in the notification tab. And the phone performance along with battery performance is reduced even though there is not so much memory used and phone usage is also very minimal.
    My phone is about to turn two years!
  17. OALEXANDER
    Indian POC Assistant Head Moderator Aug 19, 2019
    OALEXANDER , Aug 19, 2019 :
    Hi,
    please would you be able to translate in English . Thx
  18. 悬崖不勒马
    悬崖不勒马 , Aug 19, 2019 :
    OK,I will have a try. When I use the "Multile users". The new user can not set the "Screen calibration". Because there's not such option in the settings. But I think the option is really important for OP3 users. "sRGB" makes the screen display better
  19. DonHartnett
    DonHartnett , Aug 19, 2019 :
    Do you mind if I ask are you usually on data or wifi?
  20. DonHartnett
    Is it easy to downgrade to Oreo?
