181
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. O1521668246656
    Cupcake Aug 19, 2019
    O1521668246656 , Aug 19, 2019 :
    Most of the day mobile data. At the evening for like 2-3 hours wifi. Battery life and data speed is the same like Oreo. At some points in my house I had a very bad or no signal, after this update I can watch videos in this rooms without problem.
  2. O1521668246656
    there a videos links in this thread how to downgrade.
    Do a clean install and you won't have to downgrade, because the performance is like oreo
    ghostofcain and DonHartnett like this.
  3. DonHartnett
    DonHartnett , Aug 19, 2019 :
    Sorry I don't know much about this. What's the difference between downgrade and clean install?
  4. DonHartnett
    Would you mind showing your battery usage at the end of your day with the full device usage showing?
  5. O1521668246656
    downgrade: change from android 9 back to android 8.
    clean install: delete all apps and data on internal storage and then update your phone.
  6. DonHartnett
    As in do a factory reset and then update my phone?
  7. O1521668246656
    yes I will to it tomorrow, because I charged my phone 10 minutes ago to 90%. But like I said the using time is like the same
  8. AndyRadikal
    Froyo Aug 19, 2019
    AndyRadikal , Aug 19, 2019 :
    Lol.. dream... you are raving
  9. O1521668246656
  10. Auristicpleaseignoreme
    Gingerbread Aug 19, 2019
  11. F_టి_నగేష్
    F_టి_నగేష్ , Aug 19, 2019 :
    Hi ,
    I hope that the screen on lag is fixed.
    like when we recieve a call. it rings but no display for 6-7 seconds.
    Also , the menu bar lag , if the device is on from some days .
    and camera blur /focus issue. we have to manually adjust Focus by shaking the phone .
    I hope all the issues are addressed.
  12. G_Ajay_Panigrahi_dIGd
    Donut Aug 19, 2019
    G_Ajay_Panigrahi_dIGd , Aug 19, 2019 :
    yeah its fixed
  13. F_టి_నగేష్
  14. G_Ajay_Panigrahi_dIGd
    Donut Aug 19, 2019
    wipe cache coz on my side everything is working fine
  15. DS Kiran
    DS Kiran , Aug 19, 2019 :
    I have done a huge mistake by upgrading to OOS 9.0.5, after the update system is crazily lagging,
    1.call screen responding after 5-8 seconds after the action
    2.apps are not in memory in the recent apps
    3.Battery is draining rapidly
    4.the smooth&softness of Oxygen OS is gone
    @Manu J. please look in these issues we don't need security updates but in those update place pleease provide us a stable and bug free update so that these mobiles will work with out any issues.
  16. Auristicpleaseignoreme
    Auristicpleaseignoreme , Aug 19, 2019 :
    excactly...
  17. Hemant52
    Hemant52 , Aug 19, 2019 :
    yeah same problem for me also
  18. G_srikanth_thyagaraj_xan
  19. G_srikanth_thyagaraj_xan
  20. drblamith
