183
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. drblamith
    Cupcake Aug 19, 2019
    drblamith , Aug 19, 2019 :
    Don't want any upgrade or improvement.. Just fix the smooth fluidity of user interface.. And ringing..
  2. Auristicpleaseignoreme
    Gingerbread Aug 19, 2019
    Auristicpleaseignoreme , Aug 19, 2019 :
    Thanks for the information you've shared, our DEV team is currently working on this and we'll get back to you once we have further information regarding the same.
    Regards,
    OP TEAM
    lets see if they found something strange in log :)
    maybe something is happening now.. :) ant this will be fixed
    M1566231134337 and FeliciaRS like this.
  3. M1566231134337
    M1566231134337 , Aug 19, 2019 :
    I have updated my phone. loved it every moment until.now. installed. would not boot had to hard reset. now I'm still struggling it is very slow indeed and stuttery. apps don't work and over it has ruined my phone.
    never had any previous issue's before but this has ruined my handset.
    I am deeply concerned about upgrading to the 7 in the future.
    please help me fix my phone.
    John
    president99 likes this.
  4. F_Prashant_Karmacharya_U
    Honeycomb Aug 19, 2019
    F_Prashant_Karmacharya_U , Aug 19, 2019 :
    my device is working fine( i did a clean install though).
  5. MikeMp
    MikeMp , Aug 19, 2019 :
    I am on oreo OS and want to update to the latest 9.0.5.
    Am i going to lose all data or there will be no data loss?
  6. H1518548573026
    H1518548573026 , Aug 19, 2019 :
    after this update battery is draining very fast. also it becomes heat instantly. it becomes heat if you use it for 10 minutes also. before I used to charge only twice but from day before yesterday after this update I am putting my mobile for charge in every 2-3 hrs. plz provide any solution
  7. PTuT
    Jelly Bean Aug 19, 2019
    PTuT , Aug 19, 2019 :
    Depends. Some people say with clean install they have success. Some just upgrade from the previous version. If you have encrypted phone with unlocked bootloader then you better backup your stuff prior upgrading.
    MikeMp likes this.
  8. PTuT
    How long after upgrade? If it is already few days than check if there is a rogue application. You can also safe boot and see if your problem persists. Good luck.
  9. H1518548573026
    I upgraded it day before yesterday and from yesterday this started. Where to check if there is a rogue application or not.
  10. F_Mateo_Bratanić_aDzP
    Froyo Aug 19, 2019
    F_Mateo_Bratanić_aDzP , Aug 19, 2019 :
    Too many issues on 9.0.5. The system is laggy and slow.Facebook and Google Maps slow and staggering. Games are impossible to play cause everything is in slowmotion. Unable to answer calls cause of blank screen.
    Are you so inept to fix this or you are doing this on purpose???
    I will NOT buy another Oneplus phone and advice others NOT to buy it!
  11. gewinnen
    gewinnen , Aug 19, 2019 :
    The last update makes my mobile behave so slow, and the apps not responding. Hope some thing can be done in order to fix this.
  12. Varyan
    Froyo Aug 20, 2019
    Varyan , Aug 20, 2019 :
    Please decrease all 3 animations from settings - develpers options to 0.5x from 1x & let me know if you see the difference
    tadebruijn likes this.
  13. PindurPandur
    Gingerbread Aug 20, 2019
    PindurPandur , Aug 20, 2019 :
    PindurPandur
    I'm not so happy that they screwed up LED notifications with Pie update as well as the GPS. Countless feedbacks on the problems and still nothing is better with the 5th (?) update.
    I'm not angry, rather sad.​
    I found a method to fix GPS, it's working fine now. You have to turn off adaptive battery.
    The notification problem I'm facing still with, I don't know why but the LED disappears fast, seems like if my app isn't in the background but screen is locked, the LED doesn't show up.
    If someone has a solution, please don't hesitate to tell me.
    I also have the GMaps staggering problem and the calling issue as well but those are just acceptable.
    Thanks everybody, have a nice day!
  14. pallermo
    Cupcake Aug 20, 2019
    pallermo , Aug 20, 2019 :
    9.0.5 update fixed for me a lot of things...call answering, lag, speed...
    But, now mobile data is fckedup.
    Anybody with mobile data problem?
    Kalyan likes this.
  15. ghostofcain
    Marshmallow Aug 20, 2019
    ghostofcain , Aug 20, 2019 :
    If you don't need updates or security patches, then roll back to 5.0.8 job done.
    There shouldn't be data loss, unless you have an unlocked bootloader and encryption, but never hurts to have a backup of important data.
    Auristic and MikeMp like this.
  16. balu902
    Eclair Aug 20, 2019
    balu902 , Aug 20, 2019 :
    Tha
    Thanks for the information, it solved the mystery for me too
  17. president99
    Froyo Aug 20, 2019
    president99 , Aug 20, 2019 :
    M1566231134337
    John​
    Same bro. One plus neglected us. I don't buy one plus product anymore[e]1f620[/e][e]1f620[/e][e]1f620[/e][e]1f621[/e][e]1f621[/e][e]1f621[/e]
    m.parvage likes this.
  18. atulclassic
    Honeycomb Aug 20, 2019
    atulclassic , Aug 20, 2019 :
    None of these issues.
    I have made a small video of my UI which clearly shows there is no stuttering but due to file size restriction, couldn't upload it here
    will post URL instead
    https://drive.google.com/open?id=1uZV94ER5JPYuZ_YH1jRXuLZ5s-rLugVb
  19. m.parvage
    Froyo Aug 20, 2019
  20. astralbee
    Ice Cream Sandwich Aug 20, 2019
    astralbee , Aug 20, 2019 :
    I had issues with 9.0.4 like most people - but nothing serious before that - and 9.0.5 seems to have fixed most things, at least everything I use. 9.0.4 was just a bad build. I play a few games, nothing really graphic intensive (I prefer the pub to pubg) but I have not experienced anything like you describe. Something must be wrong with your phone, or, more likely, wrong with your update. You should try a full wipe and reinstall of the latest build. I did a full wipe before i installed 9.0.5 and all is great.
    Oneplus have their faults and failures but the phones have been open to developers and as such there are more guides to fixing issues like this and flashing updates to OOS yourself than for most other phones. You can easily find a guide to fixing your issue so search for that instead of coming here to moan.
    ghostofcain likes this.
